Remove Battery
Old Aug 4, 2008 | 11:11 AM
madnaz's Avatar
Question Remove Battery
How exactly is the g35 battery supposed to be removed?
Thanks
Old Aug 4, 2008 | 11:16 AM
Hi-TechG35's Avatar
Newbie....lmao...lol okay heres how its done:
1. First you remove the cover on the passenger side.
2. Remove the clips that hold the plastic trim
3. Using a 10mm socket disconnect the negative terminal
4. Then remove the positive terminal
5. Unclip the fuse box (you might need a flat headed screwdriver or can pull gently)
6. Using the 10mm unscrew the battery tie down
7. Pull the battery out (needs a little manuvering since it's in there tight and your done
Old Aug 4, 2008 | 11:26 AM
iamericgee's Avatar
great write up!
Old Aug 4, 2008 | 11:29 AM
madnaz's Avatar
haha thanks...it was the fuse box that got me
Old Aug 4, 2008 | 11:36 AM
Hi-TechG35's Avatar
^No problem. It's a PITA at first but once you do it a few times it's quite simple. The battery is real snug in there though.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
