What gas octane do you use?
Old May 7, 2004 | 03:35 PM
onefastg35's Avatar
Re: What gas octane do you use?
I live in Jersey not So Cal I never new you guys dont have 94 anywhere.
03 6mt black/black
Ztube JWT PopCharger
Old May 7, 2004 | 04:20 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
91 is the highest I've seen in SoCal since they cut 92 out
2 G or NOT 2 G, there is no question!
Old May 7, 2004 | 04:26 PM
Msedanman's Avatar
O.F. Administrator
Up here in Ontario, I use Petrocan gas -- super, which is 91 octane. It has Techron in it like your Chevron does.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old May 7, 2004 | 05:42 PM
Mooser's Avatar
About 15 years ago, some of our local, independant "Thrifty" gas stations were pumping 94 octane. Do you remember that? I used to run it in my Mitsubishi pickup all of the time. But like everything else, nothing good lasts forever. [img]/w3timages/icons/tongue.gif[/img]
2003-G35C-5AT Laser Red/Black/Prem/XM/Tint/Chrome 17's/Black Badged
Old May 7, 2004 | 05:47 PM
Z2G's Avatar
Z2G
yeah, here in nor-cal, we only get 91 as well. just curious though, is it much different with 91 vs 93, 94, or higher?
Old May 7, 2004 | 09:27 PM
Ventural's Avatar
Florida G35 Club Charter Member
93 octane only. Highest I can find locally. The Sunoco's that are nearby only go up to 93.
Old May 7, 2004 | 09:44 PM
BeachNative's Avatar
91 Octane Chevron Supreme with Techron. The highest available round here...
2004 6MT/Coupe/TB/WI/Premium/Aero
Old May 8, 2004 | 02:08 AM
SoCaLG35Mashin's Avatar
No need to go higher than 91 for the coupe. The ignition timing was tuned for the engine to run at 91. Run lower and you run the risk of setting off the knock sensors, which will result in ignition timing retard and will lower your engine performance. Run higher than 91 and you are just wasting your money, unless you are running high compression with FI and have the need for higher octane.
04 6MT Coupe
35% Madico smoke tint /CF Hood /Injen Cat-back
Old May 8, 2004 | 05:04 PM
Ventural's Avatar
Where I live, Sunoco uses 93 octane and they are three cents cheaper per gallon than ExxonMobil & Shell (used to be a Texaco) which are using 91 octane. $2.03 (93 Octane) vs $2.06 (91 Octane) as of this morning.
Old May 9, 2004 | 06:10 PM
G35_TX's Avatar
This is not true. 93 octane does make a difference. Put the highest you can.
2004 Infiniti G35S, 6MT, Premium, Sport, DP
Mods: JDM Clears, 20% tint, Z-tube, K&N Drop In
Track: 14.32 at 97.6 mph 2.196 60ft (1900 miles bone stock, with bogging)
Old May 9, 2004 | 06:17 PM
Tybrey's Avatar
I use Sunoco 94 ultra. It is cheaper than most other gas station's 91 octane.
"Not all G35 owners are G35 Drivers"
2004 G35 Coupe 6MT-BS/BLK | Full Aero-Navi | Gounding Wires | Clear Corners | 35% Tint | 350Z Tube | JWT PopCharger | Passport 8500 |
Old May 9, 2004 | 09:51 PM
G35_TX ()
05/09/04 03:10 PM
<hr></blockquote>
Please explain how it "makes a difference"
04 6MT Coupe
Old May 9, 2004 | 11:02 PM
SlayerGTR's Avatar
So its said that gas will hit 3 bux per gallon by summer? o_O go lexus, 2007 all models will have a hybrid version lol
SAVE GAS NOW b4 it gets 2 expensive in the future due to rarity
Old May 10, 2004 | 10:51 AM
a.k.a. RANDYS_G
15 years ago I was 12 and could care less what gas was available! =)
Old May 21, 2004 | 02:06 PM
  #30
ironrice's Avatar
Does it matter if you use different gas companies? I heard that if you stick to Exxon stick with exxon gas, it's better for your car. But does quality of gas really differ that much between gas companies?
