What gas octane do you use?
My co-worker has run 87 in his '03 5AT Coupe for years and says he doesn't have any problems with it although he has never given it more than half-throttle and isn't the kind of guy that would probably detect engine noise...
I on the other hand purchase 91 Octane since that's what they offer in Phoenix but I drive a little harder than him from time to time.
I know on my bike I gain a extra 8hp an that was a half 110/91, I'm gonna dyno the G next
I use 93, but I don't ping as much as I used to. Just use this every 3000 miles or so.
Amazon.com: Lucas Oil 10512 Deep Clean Fuel System Cleaner - 16 oz.: Automotive
I don't know if anyone else uses this stuff, but it works almost immediately.
I run 91 octane, Costco gas, and honestly can not tell the difference between name brand gas (name brand = specific additives, nothing more) and Costco gas. I have tried hard to justify the extra 20-25 cents per gallon for Chevron (after you apply the 2% Costco Amex discount), but simply cannot. Some of the local grocery store gasoline points help level the playing field, but even with those, Costco normally wins on price and I'm not restricted on where I can buy groceries.
I have lived in other states like TX with the same car, and have to say that the car runs noticeably better on Texas fuel as compared to CA.
What I have often wondered is if your mileage will actually improve slightly (under normal driving conditions) by using lower octane fuel? For instance, if I am causing my timing to retard slightly to accommodate detonation that could occur, wouldn't this use more conservative fuel maps/timing as a result, improving mileage? Obviously, timing closer to Top Dead Center improves power, so this will not yield the best overall performance, but it seems at least on paper that mileage should improve.
A couple years ago I contemplated getting dyno tuned for 87 octane because that's when the Mustang and Camaro came out rated ~300 crank hp with unleaded regular gas. It's not like I would come close to that rating because those cars have bigger engines with direct fuel injection. On my usual 93 octane my navigation says I get 19.2mpg doing my usual daily suburban driving. I got a little over 20mpg during the early spring when temps were highs of 50s.
I've been running 3/4 of a gallon of E85 per 1/4 tank then topping off with Chevron 91... made a big difference, no ping and better throttle response BUT mileage went DOWN about 2 mpg. But then again I didn't buy it for feul economy!
I hear a lot of rumors about it slowly destroying engines that weren't built for it, but they were all rumors, so I don't know how much you can trust them.
Fuel octane levels need to be compared to oil viscosity. Each engine has a specific requirement and changing the fluid doesn't generate the power, it merely allows the engine to achive 100% potential. Too many misconceptions these days about higher octane gas being "better" and making more HP. Too many variables to make a blanket statement like that.
For your average, stockish, street driven car, stick to what's in the owners manual. The engineers who designed your engine trying to wring every bit of HP and fuel economy out of it know what they are doing.
BTW, i think Sonoco 110 is leaded gas. Might want to be very sure before pumping it in. Works great in a carbed race car with no converters, but you don't want leaded gas in your emmissions equipped street car
http://www.racegas.com/fuel/1
thanks to all who responded.
Here it doesn't really matter it's a Premium (91/95) or Super (93/98) = they cost roughly the same 1,27$ and 1.3$ per-liter.
Very interesting is that MPG was a little bit better with Super 93/98 fuel, than Premium 91/95.
Also performance got better (perhaps it's psychological
Yeah my choices are 87 89 or 93 so I always use 93 and my car runs beautifully, and I never have the pinging that people have even when they are using 91 octane, which is their premium. Either way you definitely should not use cheap gas or race gas, just use premium 91/93 octane gas and you'll be fine.
When I was back in TN it was 93 but now since Im stationed here in AZ I use 100 or 100/91 mix or sometime 110. When I use the 110, my car reacts like I am back at sea level. But I am built and boosted so I have felt the change just between locations.
