07 g, pinging on premium??
Old Oct 6, 2008 | 05:21 PM
grazsrootz's Avatar
i have noticed this for a while now, my car pings under when under 2500 rpms, especially right when i shift from 1-2 or 2-3 it pings a little bit i ALWAYS use premium, does anyone else have this problem? does my car need service?
Old Oct 6, 2008 | 07:11 PM
NismoG35S's Avatar
wat G? i know the new g37s need to use a "special oil " that nissan supplies to prevent engine noise, as well as the 09 maximas. not sure if your talking about coupe or sedan. either way this doesnt apply to you so have you tried a different gas station? i had a station giving me false premium a couple times.
Old Oct 6, 2008 | 08:48 PM
twin001's Avatar
Do the oil consumption test. If excessive oil is getting past your rings then it's diluting the octane of your gasoline, thereby causing pinging. You need to talk to your dealer about this and search for oil consuption on this forum.
Old Oct 6, 2008 | 08:53 PM
grazsrootz's Avatar
i am doing the oil consump test right now, it needs to go back to the dealership in about 100 miles thanks for your input i will let you guys know what happens\
edit: it is a 2007 g35 coupe
Old Oct 6, 2008 | 10:40 PM
V35 Skyline GT's Avatar
6MT Coupe
Yup I ping too. Cali 91 oct, 298hp revup VQ. It sux when it pings. Worse on hot days and even more so when everything is heat-soaked from sitting for a bit, then drive again.
Agree about OC killing oct. My old VQ was a burner and ping got worse as the OC continued. My current VQ not as bad with OC, but still is pinging as described above.
Old Oct 7, 2008 | 08:48 AM
twin001's Avatar
Originally Posted by jonahlw
I have the same problem. It pisses me off so bad to buy an entry-level luxary car and have engine issues like this. Dealer won't do anything about it. I like my G and am going to keep it a while, but next car's not going to be infiniti.
What do you mean the dealer won't do anything about it. If you fall within the guidelines of the TSB then they should replace your engine. You may need to go to a different dealer.
As far as the 91 octane goes, that's not the issue. Locally we have 91 that is 10% ethanol and I have no pinging issues.
Old Oct 7, 2008 | 11:10 AM
6MT Coupe
Then there must be another underlying issue with mine (I have many theories), being my VQ replacement has minimal OC now and only runs on Shell V-Power 91.
See you have the Osiris tune...that's why you don't ping on 91
Old Oct 7, 2008 | 12:36 PM
Maxypad's Avatar
If you live in the southeast recently people have been saying the premium gas is ****ty cause of the shortage bs after that hurricane but i haven't been having any problems
Old Oct 7, 2008 | 04:43 PM
twin001's Avatar
They just won't do it. I told them, and they say they can't hear it. Same with rattles, "cannot duplicate". They make me feel like I'm some weirdo that is a car hypochondriac, but it's definitely really noticeable, annoying, and when I drive like 3+ hours, it absolutely kills my performance b/c it gets heat soaked so bad, the pinging is nonstop and the engine pulls lots of timing.
I burn a quart every 2000k miles, so oil consumption is acceptable, though I do notice a lot of blow-by in the plenum.
OP let me know if you are able to fix yours.
where are you located? How close is a different Infiniti dealer? When you are burning 1qt every 2k miles how are you driving?
Old Oct 8, 2008 | 04:55 PM
RunLevelZero's Avatar
Get in the car and go with them
Sure they'll tell you they can't hear it because they may possibly need to give you a new freakin engine. Tell them you want to go with and or drive the car yourself with the technician in the car. He can't deny it if your right there with him and you hear it.
g.spot
May 9, 2016 10:54 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
c_elliott83
Sep 25, 2015 07:55 AM
reaper76
Sep 20, 2015 11:59 AM
bigmike
Sep 17, 2015 01:58 PM
