driver side carpet under mat always wet after it rains!
Old Oct 10, 2008 | 03:50 PM
imRACERX's Avatar
anyone have this problem/fix? it seems to get real damp under driver side mat on carpet and smells of mildew untill it dries. anyone?
Old Oct 10, 2008 | 05:12 PM
RunLevelZero's Avatar
Have you drilled through your firewall at all? Did you crawl underneath to see if something poked a whole? Sounds like you got one somewhere if it's only when it rains. Is it there when you are not moving? You need to probably get it in and looked at before mold starts to grow if you really do have a leak.
Old Oct 10, 2008 | 10:22 PM
imRACERX's Avatar
well i havnt looked underneath or pulled the carpet up before posting here to see if it was a commmon thing with the G
Old Oct 10, 2008 | 10:59 PM
GreenGoblin's Avatar
The goblin resurrection
mine does it also
Old Oct 10, 2008 | 11:06 PM
G35Ian's Avatar
Have you had your windshield replaced? It could have a leak in the urethane or a rubber grommet in the fire wall could be missing or dry rotted allowing water in your car.
Old Oct 10, 2008 | 11:53 PM
imRACERX's Avatar
no but it got me thinking it may be caused by the huge gauge amp power wire i fed through but unlikely. maybe we can diagnose thiss at towers. im not gonna worry about it.
Old Oct 11, 2008 | 12:36 PM
PedalKick's Avatar
I had a similar problem on my 95 Maxima. The plastic drain tube in the drivers A pillar that lets water out of the sunroof trough came detached from the drain at the top of the pillar. When it rained or I washed the car it would run down the inside of the pillar onto the floor. It took me a while to find it. I poured water directly into the sunroof drain and it started leaking out of the pillar. I was able to pull down the corner of the roof liner to get the tube pushed back on it's spigot. So use a hose to help find the leak. Start low at the cowl area first. If no water shows up, try the sunroof.
Old Oct 12, 2008 | 07:43 PM
Mark_V35's Avatar
this used to happen in my 180sx. It was because the rubber grommets which had all the cables running from the boot to the car were removed, also i had no inner splash guards so thats why the water was getting into the grommets and into the car
Old Oct 12, 2008 | 11:00 PM
imRACERX's Avatar
i guess i will have to dx this. i will start from the hood then look under finally if nothing, look from the top. thanks John
Old Dec 12, 2008 | 08:43 AM
orl-g's Avatar
any luck with this racerx?
im up in orlando and having same issue on drivers side.
im lucky i have good mats as all the water pools up on the mat and not on the carpet. only after hard rains tho...wtf???
Old Dec 12, 2008 | 08:48 AM
fluffy's Avatar
My 05 mustang had the same issue....it was the passenger cowl....check to make sure its attached correctly or if its cracked....
Old Dec 12, 2008 | 09:11 AM
orl-g's Avatar
"passenger cowl" ??? i must be a newb...
is this the plastic trim peice b low the windsheild?
where the wipers sleep?
Old Dec 12, 2008 | 09:14 AM
fluffy's Avatar
yes, it's held on with couple of plastic screws...once you pop it out, you'll see the cabin filter slot...
Old Dec 12, 2008 | 09:34 AM
orl-g's Avatar
thnk u fluffy
Old Dec 12, 2008 | 09:43 AM
fluffy's Avatar
