2nd Gear is howling from 2000rpm
Old Oct 26, 2008 | 08:52 AM
rx8wanki's Avatar
I was just wondering if it is normal that my 2nd gear is howling everytime I go over 2000rpm.It lasts up to 6000rpm until I shift in the 3rd gear.Its not that loud but I hear it every time when Im driving without any music.
I have a 2006 Coupe 6MT.I this isnt normal will it help to change the transmission oil?!I can shift all gears properly until now.
Old Oct 26, 2008 | 03:04 PM
rob40wilson03's Avatar
not quite sure what you mean.... is it a whistling noise that sounds like its coming from under the hood? if so, its from the stock airbox which has a whistle in it and its normal
if thats not what you mean, then i dunno
Old Oct 26, 2008 | 04:08 PM
rx8wanki's Avatar
hmm it is hard to explain but I think it comes definitely from the transmission.the whistling from the airbox would be always there not only in the second gear or am I wrong with this opinion?
Old Oct 26, 2008 | 04:27 PM
officerdbag's Avatar
check out your rear diff.. mine just went out and would whine everytime on the throttle
Old Oct 26, 2008 | 04:33 PM
Old Oct 27, 2008 | 11:43 AM
Maxypad's Avatar
I haven't heard that noise but every time I shift into second at a slow speed and start to accel just a little bit i hear this like clunking noise coming from the gear box i think but if im going from first to 2nd under hard accel. then it doens't happen
Old Oct 27, 2008 | 02:34 PM
tsfg35's Avatar
I am having the same noise from my 6MT. If you are in second and low RPMs and then punch it still in 2nd, it makes that noise, right?
Old Oct 27, 2008 | 03:12 PM
rx8wanki's Avatar
@tsfg35
Yes your description fits 100 percent on my problem now we only need one who can say us how to fix this
Thebaws11
Jul 2, 2021 11:36 AM
beto4632
Sep 23, 2015 04:28 PM
Since 1983
Sep 19, 2015 10:26 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
