Slip/E-Brake/VDC Light
Old Nov 2, 2008 | 06:37 PM
shockedimpy's Avatar
This issue has just occured on my car the last few days.It seems to happen when I push the car a bit. The Slip/E-brake/VDC light will automatically come on and stay on....Anyone know why my car is doing this? And what could be wrong. It did it on the way to work when I drove completly casually.
Old Nov 2, 2008 | 08:29 PM
tragedycat's Avatar
I had that happen a few weeks ago, it was because my camshaft position sensor went out. Got it fixed under warranty for free.
Old Nov 2, 2008 | 09:01 PM
pwrobel's Avatar
check your brake fluid. if it is low those lights will come on. that would indicate that you need brake work
Old Nov 2, 2008 | 09:02 PM
Canadian's Avatar
Canada, eh?
Brake fluid is low. Fill it to max.
Old Nov 3, 2008 | 01:00 PM
Is brake fluid something I can buy at Autozone and is it cheap?
Old Nov 3, 2008 | 01:42 PM
LittleItalyG's Avatar
^^^ uhh, yeaa
Old Nov 3, 2008 | 01:47 PM
brafael650's Avatar
this happens to me when my brakes needed to be replaced. check the pads and top off the fluid.
Old Nov 3, 2008 | 01:55 PM
Sandman's Avatar
What he said. As your pads slowly wear down, the brake pistons have to push farther and farther out to make the pads contact the rotors. Since the pistons are extended further, the fluid level in your brake fluid reservoir drops, and this can trigger the three lights you're talking about.
I would bet that if you top off your brake fluid to the MAX line the lights will probably go away, but it won't fix the underlying problem. You should definitely get the pads checked out (or do it yourself -- it's pretty easy).
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
