HELP! Immobilizer triggered?
Old Nov 21, 2008 | 12:16 PM
jonnyfin's Avatar
I'm afraid that I may have triggered the immobilizer in my G35 I had a new key cut/programmed yesterday and it worked initially, from the locksmith back to work, but when I attempted to leave for lunch the car wouldn't start.. just turns over but never catches & alarm light stays on. This happened before and usually I'd just use my original key and it'd turn on but this time it doesn't.. both keys exhibit the same symptoms.
What I've do so far..
Disconnected battery and pumped brakes to clear the capacitors
Used keyfob to lock / unlock car with several door close / opens.
Held one key under the steering wheel while I try to start the car with the other..
I called the locksmith and they can send someone out to reprogram the key but they're not sure it'll work as it might be the car instead of the key
Any advice? Thanks!!!
Old Nov 23, 2008 | 03:35 PM
jonnyfin's Avatar
Still begging for help, someone save me from the stealership!
Old Nov 23, 2008 | 05:41 PM
Dranom's Avatar
where did you get the key? ebay?
Old Nov 23, 2008 | 06:22 PM
jonnyfin's Avatar
yup, remotehub is the seller.. stay away as he doesn't use the correct transponder
Old Nov 23, 2008 | 10:54 PM
jutn35's Avatar
G35 Coupe
im jw, did u look in ur car manual, bc i thought i had this happen to me , but there should be somting in there ,i read it but forgot
Old Nov 23, 2008 | 11:45 PM
jonnyfin's Avatar
Tried this, from page GI-3 of the FSM
● When failing to start the engine first time using the key of NVIS/IVIS (NATS), start as follows.
1. Leave the ignition key in "ON" position for approximately 5 seconds.
2. Turn ignition key to "OFF" or "LOCK" position and wait approximately 5 seconds.
3. Repeat step 1 and 2 again.
4. Restart the engine while keeping the key separate from any others on key-chain.
didn't work though.. gonna try the manual code reset method listed here tomorrow: http://www.g37-tech.com/wiki/How_To:ECU_Reset_Procedure
Guess it's off the stealership or back to the locksmith after that..
Old Nov 24, 2008 | 10:18 AM
conrad_s13.5's Avatar
https://g35driver.com/forums/faq-diy...r-key-fob.html
^^ did u try this?
Old Nov 24, 2008 | 04:29 PM
jonnyfin's Avatar
Originally Posted by conrad_s13.5
Yup, gave that a go but unfortunately it didn't change anything. I went ahead and picked up an Equus 3100 ODBII scanner to determine the P code but there are apparantly no codes stored in the computer.. hmmm. Think I'm gonna call the locksmith to reprogram my Ilco as the computer may be a-ok.. are you hal?
Old Nov 26, 2008 | 02:45 PM
jonnyfin's Avatar
locksmith was able to reprogram original key
bananax
Sep 24, 2019 12:24 PM
Depravity
19 Inch
55
Oct 16, 2015 01:36 PM
dcsbh1
Oct 1, 2015 03:15 PM
lilscsteve
Jul 21, 2015 04:01 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
