Will This Give Me Hp?
Old Dec 3, 2008 | 05:21 PM
dofu's Avatar
20 Year Member
Originally Posted by Roguewolf
the mods i got for "POWER" are FI high flow cats, meagan Y pipe, Crawford plenum (or spacers). U get nothing from a exhaust other than noise. im sure ur making 1hp to the crank or so.. but it's not noticeable. Intake is pure cosmetic/noise. I've actually seen dynos where the owner LOST a hp or two lol. a tune is crucial of course but thats only once u get all the bolts ons u want then get a tune to get them to all work together. Now if u REALLY want power.. the only power that will kick u in the ***** is going FI (turbo/sc) everything else ur just messing around. nissan(infiniti) squeezed out 287-290 hp out of a 3.5 v6 can't really get much more out of it unless u put it on roids.
Although you can make small gains with i/h/e, it mostly shifts power to different rpms depending on the set-up. With this car, I'd say the aftermarket intakes, and aftermarket y-pipes can be worse than stock. If you change the design around a bit for better/smoother flow, you can gain a bit more performance.
Originally Posted by silverbullit05
ok these guys on here must be crazy. i have had my 05 coupe base line dynoed and then dynoed with stillen exhaust and pop charger. base line 248 and with mods 264 if thats not a gain then i dont no what is. oh yea those are whp numbers. i put much more on since then im getting it dynoed soon. you should gain to the wheels roughly for headers 5 to 7, hfc 8 to 10, cat back 7 to 9, intake 1to2, plenum spacer 3 to 5, mrev 2 with plenum spacer 8 to 14, and tune will depend on whats been done to the car. i have seen most of these parts being dynoed on my friend 06 coupe. however the best mod garrentied hands down is the mrev2 w/ plenum spacer. thats where his biggest gain was so far. i also ran into another member on here at a meet that has greddy e-management and he had it tuned with a gain of 42whp. on stock exhaust, hope this helped you
With the mods you have now, MREV2 with spacer will not get you 8-14hp.
Old Dec 4, 2008 | 12:33 PM
silverbullit05's Avatar
ive seen it with my own eyes on a 06 g35 with stillens pop charger z tube and stillen true duals on a superflow dyno! do my eyes lie?? and the exact gain was 12.7 hp at 4600rpm and a peak gain of 7.9whp at 6400!!
Old Dec 4, 2008 | 04:01 PM
Canadian's Avatar
Canada, eh?
Same day? Same time? Same weather? Same location? LOL dyno chart please.
Old Dec 4, 2008 | 04:52 PM
dyno run before install was around 8am it was 45deg. however i did not see the base dyno run i had just missed it. right after they put the mrev2 and blox plenum spacer along with motordynes isothermal gaskets and coolant diverter valve and isothermal throttlebody spacer. then he drove the car hard all day until about 4pm car sat about 1 hour before dynoed again temp was 52deg. i havent seen him in a while but as soon as i see him ill get the dyno sheets. i will tell you this i have dynoed my 05stock and modded on both dynojet and superflow dynoes i find dynojet can fluctuate where superflow is very close. i did 5 pulls on each both stock and modded. superflow started out low at 242 then by pull 3 was up 248 and both pulls after where within 1 to 2 hp dynoed with 10min cool downs between pulls. same on dynojet but hp started at 231 the sencond was 247 third 239 fourth 242fifth 249 so i did trust those dyno #'s. dynoes where done stock on the same day temp 70deg. also trq on dynojet didnt even seem right at 235, superflow shown 228 steady. so when i modded i/e i dynoed 16 hp more on superflow on a 80deg day and dynojet gave me a max of 19hp. so i chose the lower number as its probly more accurate
Old Dec 4, 2008 | 05:14 PM
dofu's Avatar
20 Year Member
Is the power curve the same?
And like I said, there is no way you gained 14hp with MREV2 and spacer. Hell, the thing won't even get you 8hp... maybe if you were boosted...
Old Dec 4, 2008 | 07:06 PM
releasedtruth's Avatar
My Big Papi bobblehead gives me 19 peak hp, just from the smile alone. Always feels like a troller when it's 50 posts or less...
Old Dec 4, 2008 | 08:49 PM
blaccG35's Avatar
if you send your ecu out then you gone need a back up car thats too much of a hassle,,.how long does it usually take if anybody knows?
Old Dec 4, 2008 | 09:47 PM
dofu's Avatar
20 Year Member
Then get the Osiris. Not much downtime involved... just gotta load the programming.
Old Dec 4, 2008 | 10:59 PM
blaccG35's Avatar
what is osiris???
Old Dec 4, 2008 | 11:20 PM
gary c's Avatar
HKS exhaust =, 0... intake = 0, spacers = 11-14hp, headers = 0 (unless u tune)
If what you posted is true why did you make all the mods you have listed?
Three years ago at least two of the import mags were squeezing HP from
our cars not to mention my favorite Nissan Sport. Every one found that
exhaust and the MD spacer created quite a substantial amount of RWHP. That
information alone was enough to arouse my interest in all the mods you have
listed as worthless!
Gary
Old Dec 4, 2008 | 11:25 PM
dofu's Avatar
20 Year Member
what is osiris???
IMO, it's the best reflash currently available for our cars. Lots of info here about it, just do a search.
http://uprev.com/
Old Dec 5, 2008 | 12:06 AM
blaccG35's Avatar
^thanks for the link
Old Dec 5, 2008 | 12:36 PM
silver g's Avatar
http://uprev.com/
Just FYI...You know Tadashi at Technosquare sells all the ECU codes to tuning companies in North America as well as Japan...Osiris most likely got the info for their software from him. He is the only guy capable of cracking the ECU's in North America...which is why Nissan of North America sends him all the new vehicles to crack the ECU's.
Old Dec 10, 2008 | 09:32 AM
ichiban101's Avatar
"nissan(infiniti) squeezed out 287-290 hp out of a 3.5 v6 can't really get much more out of it unless u put it on roids."
the 350z had more hp from the factory then listed and it had the same displacement. so there are items that can be added to increase the hp output on the 287-290 hp engines.
Old Dec 10, 2008 | 11:07 AM
  #30
Roguewolf's Avatar
Gary
well the only mod i've done performance wise is a HFC and a crawford and maybe the y-pipe. as far as the intake it just sounds more agressive. I'm sure with all this i'm prolly not making 300hp to the crank. and i said u can't squeeze "much more" meaning i m sure u can get a couple more hps out but ur not gonna get noticeable diff unless u go FI.
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
