rattling noise????
Old Dec 28, 2008 | 04:37 PM
uhohitzmikeo's Avatar
rattling noise????
06 MT coupe
i have this rattling noise if there is complete silence with my windows rolled down and im driving next to a high wall or in a tunnel. if im driving in the open not next to anything such as a wall i dont hear anything. i only hear it if i intend to look for the sound if you know what i mean other than that i dont hear anything. it sounds like 2 pieces of sheet metal banging on each other or spare change in your pocket. it sounds like its coming from the front of the car. i searched and read a lot about noises and rattles and was wondering if this is one of the normal ones.
Old Dec 28, 2008 | 07:11 PM
Drowe303's Avatar
yea mine does that to. really annoying. especially when u look for it.
Old Dec 28, 2008 | 09:15 PM
uf20wop's Avatar
mine does it too... it's pretty annoying i don't know why it does that
Old Dec 28, 2008 | 09:19 PM
bocatrip's Avatar
Our cars can be a symphony of etraneous rattles.
Old Dec 29, 2008 | 01:32 AM
ZIG35's Avatar
I found out today what was rattling on my G. I had the exact same sound triggering off and on depending on range of rpms. There is some sort of black sheet panel just in front of the muffler ("front" meaning towards the engine if laying under the car at back bumper area). It seems to only be held by two small bolts. I was able to identify it as the problem by parking inside the garage to enclose the sound waves emitting from the car while engine idling and reving and idling again to catch sound at different rpm's. You might try that to duplicate driving through the tunnel and/or next to wall scene where sound bounces or is enclosed enough for you to hear it.
Anyways, though I didn't get to fixin' the problem just yet since I don't have what I think I want to get, I will attempt to tackle that tomorrow. I plan on heading out to HomeDepot and picking up some washers to place in between the bolts and sheet in effort to hopefully stop the vibration sound by slightly separating the two touching points of metal (metal sheet & muffler) that bang and vibrate at certain rpms. If that doesn't help, then I'll pry into the adjoining gaps some sort of rubber spacers so that metal to metal isn't touching and creating that metal vibrating/rattling sound.
Well I found that to be my vibration gremlin. Hopefully you guys end up having the same gremlin so that identifying as well as fixing it can be a breeze.
Hope I was of help. Good luck!!!
Old Dec 29, 2008 | 10:57 AM
if u find a good fix....try to take some pics along the way so we can all see too.
Old Dec 29, 2008 | 11:33 AM
STCLAIRWEST's Avatar
welcome to infiniti
Old Dec 29, 2008 | 12:07 PM
07PEARL6MT's Avatar
+1 FTL
Old Dec 29, 2008 | 02:02 PM
BostonG6spd's Avatar
i have the same rattle.....
Old Dec 29, 2008 | 05:51 PM
azng45's Avatar
so do i.. .. sound so cheap
Old Dec 29, 2008 | 09:59 PM
OG_35's Avatar
there are other threads discussing this. if your g is under warranty, the dealer should fix it for free.
Old Dec 27, 2010 | 10:25 PM
Wuzdarap's Avatar
Rattle
I have the same rattle, what's the update on this?
Old Dec 28, 2010 | 03:49 AM
krypton's Avatar
I hear rattle mostly when it's cold outside. Recently, my passenger door/window started rattling when I shut the door. I was pretty sure that the glass was loose and was going to to follow one of those DIY take off door panel to check it out. I put my car in garage overnight and in the morning this rattling/banging completely dissapeared. Unfortunately I can't keep my car in garage all the time. Anyone else has this problem in cold weather ?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
socaldavid
Sep 5, 2015 04:35 AM
