Codes
Old Mar 21, 2003 | 05:09 PM
RamboRami's Avatar
G35driver.com Moderator
Re: Codes
im in the process of getting one [img]/w3timages/icons/smile.gif[/img]
<font color=green>-Ramb0</font color=green>
Old Mar 21, 2003 | 05:39 PM
ryoken's Avatar
Re: Codes
Yes, but is anybody in the process of getting a Consult 2 device? [img]/w3timages/icons/smile.gif[/img]
Old Mar 21, 2003 | 06:46 PM
Gordgee's Avatar
Administrator
Re: Codes
Ryoken:
I've heard some dealers deny that the changes are possible. That's the reason why I scanned and posted the actual sheets. As I said in an earlier post as well, there was an error re the Custom Auto Light Setting. Mode 4 is the Least sensitive. Not sure if there're any other mistakes on the printout.
Because these are CUSTOM settings that take the techs a bit of time, I would expect that they can charge to do them. Otherwise, some might abuse this and request changes just to try out, change back and forth, etc. Those that are able to have this done as a courtesy service need to keep this in mind, and not abuse the service. This may have happened in the past, which is why some dealers either deny that it can be done, or charge for it.
BTW, from what I've seen, each change can take up to 15 minutes, not including the Consult II printout (at the bottom of the second page). I'm sure the shop's set rate is considerably higher though![img]/w3timages/icons/laugh.gif[/img]
<font color=green>GG</font color=green>
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
