Oil Newb
Old Jan 20, 2009 | 02:59 PM
jutn35's Avatar
G35 Coupe
Question Oil Newb
Ok so i checked my oil and need some advice.
Type- 5w30 Full Synthetic - Mobile 1
Measure- Half point between low and High
Color- Tinge of yellow/ & black
Miles on oil- 4100
So my brother has 10w30 Synthetic Mobile 1 oil for his supra, and im thinking of just taking a little. Is this ok since im running 5w syn ? and hes running syn ?
Old Jan 20, 2009 | 03:02 PM
Swivel's Avatar
Moderator
Don't bother, the oil level is fine. Doesn't have to be right at 'high'.
jutn35's Avatar
G35 Coupe
and the color ? should be fine , its more black than yellow
Thanks
Old Jan 20, 2009 | 03:16 PM
vhtran's Avatar
You'll be fine, I'm changing my oil at 5000+ most of the time. And yes, you'll be fine if need to add oil with dif. grading.
Old Jan 20, 2009 | 03:17 PM
jutn35's Avatar
G35 Coupe
Thankyou for all input
Old Jan 20, 2009 | 03:49 PM
johnhanson007's Avatar
I run the same oil, just checked yesterday, and the dip looked exact same as you at 3600mi.
It's been consistently at this level prior to all my oil changes, whether I baby her for the previous miles or drive the shart out of here (I've been driving hard recently...much more fun).
I'm thinking of switching to Amsoil next change and will see if she uses less. Not worried one iota though.
Old Jan 20, 2009 | 04:55 PM
SVTCOBRA's Avatar
Personally, I would just change the oil.
I also use M1 Syn 5w30
I change between 3K and 4K, but closer to 3K....
I love oil threads!
Old Jan 20, 2009 | 05:05 PM
Jeff92se's Avatar
Red Card Crew
How does it taste? That's a big factor
Old Jan 20, 2009 | 05:33 PM
partyman66's Avatar
Yes... this detail is often overlooked by inexperienced shade-tree mechanics. Good motor oil should taste like sulfuric acid. If it doesn't.... and it instead tastes like Draino, then it's time for an oil change. You may need to sample one or both of those products if you're unfamiliar with their taste.
For real though.. you should do or get an oil change done on your car if it's at 4100 miles and this is your first time dealing with oil on teh car. You can't really go by the color of the oil to tell what kind of shape it's in.
Old Jan 20, 2009 | 06:38 PM
jutn35's Avatar
G35 Coupe
ive changed the oil 2 times already, i change it around 4800 miles , usually, the longest i kept the oil was 5600 .
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
