6MT Shifter Kick?
Old Jan 29, 2009 | 08:21 PM
danny23's Avatar
6MT Shifter Kick?
I recently purchased a used 2004 G35 6MT coupe (50K miles). After coming from a 540 6 speed, I have to say this car is amazing. I look forward to modding it, and posting on this forum.
Everything seems very sound on the car, but I noticed an issue that I am curious about. In any gear if I completely let off of the gas in gear, then re-apply it, the shifter kicks slightly. I can feel it if I lay my hand on the shifter with no pressure. It isn't just the vibration because it kicks toward further-in-gear (forward in 1, 3, and 5, rearward in 2, 4, and 6). I can even see it slightly if I don't touch the shifter. It doesn't grind and the clutch isn't slipping, although the clutch has late engagement (seems normal from my searches here). My thoughts are motor or tranny mounts, but maybe this is normal? It seems like engine torque takes slack out? It occurs even if the accelerator is press slightly from a coast. Thanks for your thoughts.
-Dan
Old Jan 29, 2009 | 09:38 PM
kvangil's Avatar
I do notice very slight movement on my shifter when letting off accelerator and back on, but I wouldn't really describe it as a strong kick.... Our shifter doesn't shield vibrations well at all, so it's possible that it's normal.
On another note, what are your driving impressions of the G vs. your 540? I considered the 540 before buying the G, but didn't want to fork over that much money for the car and BMW out-of-warranty repairs down the road...
Old Jan 29, 2009 | 10:56 PM
danny23's Avatar
Thanks for the feedback. Maybe it is just normal.
I think the G is a great platform. The chassis is great, and the engineering seems phenomenal.
I do miss the torque of the 540. It had grunt unlike the G. If only I could match the motor of the 540 with the chassis of the G... That said, I wouldn't go back. The maintenance involved with the bimmer was insane. It was a very "glitchy" car. I am hoping the G is a more reliable car.
-Dan
Old Jan 30, 2009 | 11:24 AM
V35 Skyline GT's Avatar
6MT Coupe
Slight movement on mine but no actual 'kick'. I get a slight vibration too while deceling from high rpm just for a short (rpm range) period. Normal.
BMW lol aka: 'Bring More Wallet'
Old Jan 30, 2009 | 01:43 PM
true's Avatar
When you are giving the motor a lot of throttle while in gear, the transmission will naturally want to fully engage the gear. This movement of the shifter is simply the result of the transmission being fully engaged into gear with torque being applied.
Old Jan 30, 2009 | 03:02 PM
rob40wilson03's Avatar
mine moves exactly how you described
Thebaws11
Jul 2, 2021 11:36 AM
Blue Dream
Dec 5, 2015 10:56 AM
alessandro
Oct 8, 2015 09:29 AM
RWDguy4238
Sep 30, 2015 12:13 AM
