phasing out matic(j)???S
Old Mar 2, 2009 | 09:33 AM
echang0501's Avatar
I did a search on transmission oil and the wonderful people on this site told me to go to this website to get matic j oil https://www.mynismo.com/products/?id=3912&rsku=0. On here it states that nissan is phasing out the Matic j oil, and now they are selling matic s. It's a great price, my qustion is.... Can I mix the two when i do the drain. I have about 42k. and i am ready.
Please help.
Old Mar 2, 2009 | 10:17 AM
gary c's Avatar
Trans Service....?
Not sure if having the different Nissan trans fluid would harm, but by flushing
the trans you won't have any issues. With your mileage I'd flush the trans
not just drain/add fluid....!
Gary
Old Mar 2, 2009 | 11:56 AM
echang0501's Avatar
thank you for your help... I saw a vid. that i can change like 6qts. (taking oil out of the torque converter. How about if i do that would that be sufficient? I heard the flushes are bad.
Old Mar 2, 2009 | 12:13 PM
TurTLe*'s Avatar
zoom in on the picture is says J...
I think its a typo, since the info only talks about J and nothing about S.
Old Mar 2, 2009 | 02:50 PM
hurleyguys's Avatar
hay i stopped by my local infiniti dealership today and they told me the matic j was discontinued, but the matic s is the same thing as the matic j and would work fine in the 5AT.
Old Mar 2, 2009 | 03:46 PM
echang0501's Avatar
my question is can i mix the two.
Old Mar 2, 2009 | 04:47 PM
echang0501's Avatar
i know if you zoom in and it says s and j on it. But i doubt it would be a type o. They state that its the same. But i want to be sure i can mix em together.
Old Mar 2, 2009 | 04:50 PM
TurTLe*'s Avatar
well i know we cant mix matic D with J, says so on the sticker on the car. but its common sense matic D came out first and J is a revision, matic D is for my 98 maxima. To me it should/could be backwards compatible just not forward. meaning S should work for J, D
thats how MOST fluids work. Just be happy its not 90$ GTR fluid =P
Old Mar 2, 2009 | 07:27 PM
gary c's Avatar
You heard flushes were bad, how is that possible? By doing a flush you're
just adding twice the amount of trans fluid. You drain the trans, refill and
let it circulate then drain and fill one more time....how could this possibly
do damage? By doing the flush this way you're insuring all the old trans fluid
is removed/gone. When someone makes a statement ask, WHY? They
obviously don't have an answer which leads to you're passing on misinformation....
Gary
Old Mar 2, 2009 | 08:40 PM
xXHotelCrazyXx's Avatar
I wouldnt worry about it. Lucas and Amsoil are a better quality anyways.
Old Mar 2, 2009 | 09:24 PM
TofuProductions's Avatar
unless if I am misinterpreting here, I thought all we could run in our car's trans was Jmatic? not any other brands?
I heard that people have run other brands and it's caused issues?
Old Mar 3, 2009 | 12:02 AM
Of coarse the stealership will tell you that. That want people to come back to the stealership so than can rape the of $$$ every time for the product and service.
Old Mar 3, 2009 | 12:10 AM
gary c's Avatar
But what about the warranty, if your trans takes a dump wouldn't using
something other than Nissan fluids give Infiniti the opportunity to throw in
the void towel? You know how the stealership
is, any chance to not give us service without charging us is like a celebration to them....party time!
Gary
Old Mar 3, 2009 | 12:14 AM
ZIG35's Avatar
I heard changing out your tranny oil once you hit something like 45k or 50k plus is a bad thing. As a matter of fact, I believe Sears and Pepboys wont change out your tranny oil if your car is over that ballpark milage.
This makes no sense to me, but they stated it has something to do with the tranny fluid NEEDING to have the metal shavings mixed in. Being that the case, then would that not make it that I can no longer change out my tranny fluid ever??? Just doesnt seem right.
Old Mar 3, 2009 | 12:31 AM
Gary
How long is the warranty good for on the tranny?
