My first (baseline) Dyno sheet
Old Mar 24, 2003 | 09:42 PM
suprhulk's Avatar
Max RwHp: 216.4
Max Ft-Pds: 253.0
Max MPH: 145 @ 6700RPM in 4th gear
Assuming 20% loss through 5AT gives a base HP of 270.5.
Note, this was with VDC off.
Also, I did NOT hit a rev limiter. Yes, I should have tried to see what 5th gear would top out at and whether or not there is a speed limiter but every time I let up at the redline in order to upshift to 5th, the dyno operator would hit the dyno brakes. Maybe next time, after a mod (whatever that might be), I'll ask to try a run in 5th gear.
Screamin' Daemon - L5AT
Old Mar 24, 2003 | 10:54 PM
myG35ZX's Avatar
Re: My first (baseline) Dyno sheet
Either your Dyno is reading wrong or mine was.
G35 Coupe, Brilliant Silver, Premium Pkg., Tire and Wheel Pkg.
G RIFIK 1
Old Mar 24, 2003 | 10:58 PM
myG35ZX's Avatar
Woops. Its difficult to read.
First Run 221hp/214 torque
Second Run 221hp/225 torque
G RIFIK 1
Old Mar 24, 2003 | 11:00 PM
Mani's Avatar
You should have more torque as most autos do because of the torque converter...
Old Mar 24, 2003 | 11:33 PM
Mr_G35_La's Avatar
i thought the new g35c was soposed to come with 280hp ?? whats the deal with the 270 and the 215 ???? i dont understand ?
Old Mar 24, 2003 | 11:35 PM
RamboRami's Avatar
G35driver.com Moderator
Mani they both have Autos though, 20 lb/ft difference, thats alot, only 5HP difference
<font color=green>-Ramb0</font color=green>
Old Mar 25, 2003 | 12:08 AM
suprhulk's Avatar
The 270.5 is Rear Wheel Horse Power, not flywheel HP.
Most folks compute FWHP from the RWHP based upon an assumption that the drive train consumes n% of the FWHP.
With an Automatic Transmission, that percentage is usually assumed to be 20%. With a Manual Transmission that changes to 15%.
There are other factors which affect the RWHP. Things such as heat and humidity of the intake air, current engine temp, etc...
Getting 270.5 versus 280 is, as they say, "Good enough for government work." It's like the G's 280 vs the Z's 287, pure marketing BS. You gotta have something besides two seats and a boxy grill to help distinguish the Z from the G.
Conditions at the time of my run(s):
Hot. Sun was late afternoon shining inside this tiny shed where the Dyno was set up. Hot is bad. (Operator had two squirrel fans pumping air at approx 60mph at the grill to help cool things down.)
Dry. First real day of spring. Dry is good.
Depending upon conditions, another run without making any mods could result in better or worse RWHP.
Old Mar 25, 2003 | 01:10 AM
99atlantic's Avatar
maybe i'm tired and not thinking straight, but you have 253RWtq??????? that's over 300 actual torque????
edit: i'm confused, is that just 253 actual (non-RW) torque? if so, that's far below what they say it does
www.ironpumping.com
^^Bodybuilding Made Simple
Old Mar 25, 2003 | 08:29 AM
suprhulk's Avatar
Yea, that doesn't make sense.
The numbers are from a DynoJet Chassis system measured at the rear wheels via two drums.
So, yes, these are Rear Wheel numbers.
With a 20% drivetrain loss, the base engine HP figures to be 270.5 horses.
Using the same percentage that figures the base torque to be 316.25 ft-lbs.
Not exactly the published numbers of 280hp & 270lb-ft @6200rpm (though the peak was in that rpm range).
Doesn't make sense this way.
There's another DynoJet chassis system in the area, I may take a run on their system just to see if their are any major diffs.
Old Mar 25, 2003 | 10:11 AM
stewa101's Avatar
That is quite a bit torquey. But, even though the numbers may be off, I like the torque curve.
Andrew
2003 coupe 6MT blue premium aero (since 3/9/03)
Old Mar 26, 2003 | 10:28 AM
ryoken's Avatar
They intersect at 5250 if they're on the same scale. Note that the torque and hp scales are about 50 points off each other.. left and right sides of the graph.
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
