Grinding noise after startup.
Old Mar 30, 2009 | 03:17 PM
chaponius's Avatar
I have a 06 AT Coupe. Anyone else notice that after your first startup for the day, start rollin, and the first initial gear shift there is a slight grinding noise, almost as if the tire is rubbing? I'm certain its not a rubbing issue.
Old Mar 30, 2009 | 04:14 PM
Uda880's Avatar
Never had that noise, although there is a normal spring type noise that occurs in the vicinity of 10 - 15 mph at first start up that is the VDC Calibration.
Old Mar 30, 2009 | 05:55 PM
Red_G35's Avatar
Normal!
Old Mar 30, 2009 | 05:57 PM
JAYY-G35's Avatar
i have the same issue with my G & FX
Old Mar 30, 2009 | 06:00 PM
aannddyy's Avatar
I do.
Old Mar 30, 2009 | 06:46 PM
chaponius's Avatar
So if I were to turn off the VDC on startup this shouldn't occur? Gonna try this out tonight or tomorrow, I'll post back when I do
Old Mar 30, 2009 | 10:40 PM
coolieman1220's Avatar
i believe it's the ABS doing a self check, normally occurs right before shift to second gear
Old Mar 30, 2009 | 11:54 PM
Doruk's Avatar
woow i have always wondered what that was
and i thought it was something to do with vdc because it sounds very similar when vdc kicks in.
Old Mar 30, 2009 | 11:57 PM
LEON NYC's Avatar
the system is stupid, it makes ppl go crazy thinking theres something wrong, i was at that point too, like wtf is wrong with my car.....when i took it in for warranty service, i had to mention it to the reps at least 3 times, they said its the abs, but i didnt trust them
Old Mar 31, 2009 | 12:51 AM
lovemyg88's Avatar
It's normal. It's the ABS self-check, nothing to worry about. I did not try to run the car with VDC off so i dont know does the car make the noise or not. I gotta try that tomorrow.
Old Mar 31, 2009 | 10:44 AM
well when the VDC kicks in say when you take a sharp turn or lose traction wihtout using throttle, what do you think it does, it uses the brakes to try to regain traction which is done by using a motor to push brake fluid because your foot's not on the pedal! VDC is awesome and never turn it off unless you know what you're doing or you'r ein an empty parking lot. Even when you turn it off, all it does is not cut the throttle, it still tries to use the brakes so its not totally off but off enough to end up in a ditch! otherwise, pull the fuse!
Old Mar 31, 2009 | 03:56 PM
65029's Avatar
I did have same issue, dealer replaced the transmission,no more grinding and whining noise in the am specially when it's cold.
Marlin84
Apr 1, 2020 12:52 PM
magnetism80
Feb 1, 2019 10:00 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
