Burning smell when pressing gas pedal a bit hard
Old May 1, 2009 | 03:57 PM
SpLiZaaT's Avatar
hmmm I never smelt it??
Old May 1, 2009 | 04:09 PM
RADIOGUY21's Avatar
people have said when VDC activates, it can produce a slight burning smell from the use of the brakes. And VDC normally kicks on in spirited driving. Also, in the colder winter months I get a burning rubber smell occasionally, but never in the summer.
Old May 1, 2009 | 04:28 PM
p's_g35's Avatar
have you checked ur spark plugs?? just did mines and found oil in #6,#5, and a lil in 1. the valve covers are cheap as he11. hope your under 60k...cuz im not and i have to change out both valve covers out of my pocket. the seals that keep oil out is cheap. and it comes with the covers. about 400bucks...+ gaskets
Old May 1, 2009 | 04:35 PM
RADIOGUY21's Avatar
valve covers are technically covered under our powertrain warranty, 6 year/70K so you may be able to get it done for free
Old May 1, 2009 | 04:41 PM
p's_g35's Avatar
yes i know...thanks... i drive my g everywhere...from va to tn...its my dd. im about to order them next week for 430 shipped...and thats with gaskets...
Old Aug 1, 2014 | 01:24 AM
staticwhippinit's Avatar
sorrry to revive the thread
I get burning smells on hard accelerations.
how would I know that its the valve covers?
Old Aug 1, 2014 | 07:35 AM
rsingerG35's Avatar
My G does the same thing and I don't have valve cover leaks. The only way to know if oil is seeping into the spark plug tubes is to pull each coil out and look for oil. You can also look around your valve covers to see if your gaskets are leaking. The area by the dipstick tends to always have oil from checking your oil level.
Old Aug 13, 2014 | 07:40 AM
coconutman351's Avatar
I had a burning smell on my 04 6MT. It turned out my front bearings needed to be replaced as well as one control arm. Roads on Oahu is horrendous and I believe was the cause of the front suspension wear. Cost at Infiniti dealer was $2500 including discounts. Was definitely worth the spend as the suspension sounds and feels tight like a new G.
Old Aug 13, 2014 | 01:47 PM
Spartan268's Avatar
Depends on the smell. I get a burning rubber smell when I push her hard. My belief is that it's the belts, they're squealing at the moment. I believe they're cracked a bit or just needed tightening. Possibly even a combo of the 2.
Old Mar 23, 2015 | 11:10 AM
Finally replaced the spark plugs. There was a little bit of oil in the top left one. My mechanic said its not really anything to worry about. He said its the valve cover gasket but wait till it leaks more to replace it lol.
mtlruss
Dec 20, 2015 01:51 PM
03sedang35
Aug 29, 2015 07:56 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
newg37
Jul 26, 2015 09:32 AM
justgotg35
Jul 19, 2015 12:33 PM
