How low can tire wear go...
Old Jul 12, 2004 | 10:47 AM
hoshtaylor's Avatar
before it's unsafe. I already have a new set of tires that I've bought...i have 35K on my car...the front tires are fine and the back are balding...just wanted to get as much use out of them as I can....but at what point in time is it going to be unsafe...???
"Operator, give me the number for 911!"
- Homer Simpson
Old Jul 12, 2004 | 11:08 AM
Diesel1's Avatar
Moderator
Re: How low can tire wear go...
If you look at the tire, there will be indicator (wearing) strips located between in the area wear the main gaps are (either side of the center strips on the Michelins). They are placed horizontally in this water groove. When the remaining tred reaches this level, it's time to replace! Better to spend a few hundred now on new rubber rather than a few thousand on repairing your car which would be the least that could happen should you lose traction. Most reco that you change all 4 tires at the same time too.
With 35k on the car, it would also be a good time to get an alignment so you don't wear out the new tires prematurely. If you have a coupe, 35K on the Michelins would be pretty damn good!! I think most peeps may only be getting about 20K at the most!
2003 6MT Black Coupe, Premium Pkg. w/ Aero
20% tint all around, Aluminum Pedals
Old Jul 12, 2004 | 12:11 PM
Canton_G35's Avatar
my backs are at that wear mark and I have just under 15k on them.
I don't see belts yet so I'm still going. hahaha
2003 G35 Coupe 6MT/Black/Graphite/15% tint/6 wire GroundingGear™
Old Jul 12, 2004 | 09:03 PM
Brando's Avatar
Just keep riding till you hydroplane in the rain and crash.
Then.....you will be sure that you need new tires.
"I like you.....You remind me of myself when I was young and foolish"
Old Jul 13, 2004 | 09:57 AM
hoshtaylor's Avatar
took these with my camera phone...
- Homer Simpson
hoshtaylor's Avatar
and another...
- Homer Simpson
Old Jul 13, 2004 | 09:58 AM
hoshtaylor's Avatar
So i guess what I'm asking is are these too low that they're unsafe to be driving at highway speeds up to like 90 or 100...???
- Homer Simpson
Old Jul 13, 2004 | 10:47 AM
Q45tech's Avatar
As a tire wears the vulcanization continues [making the compound harder and harder and harder] this factor as much as the loss of directional water channels affects rain friction!
Michelin studied millions of tires [all brands/sizes] and found that failures increase dramatically after 2 years or 20,000 miles of use. Why long life tires and low annual mileage don't work well.
Notice Michelins new Pilot PS2 doesn't have directional channels, seems the engineers finally beat the crap out of the marketing guys. Hopefully starting a revival in non driectional tires..........we have suffered so long!
How is it that a non directional tire outperforms the best most expensive directional in wet slalom, g and road racing?
Ever notice that tires with Rain, Hydro, AQUA, etc in their name are some of the WORST WET performing tires? Especially the directional ones!
Be thankful your tires need replacing at 20,000 miles.
Old Jul 13, 2004 | 12:01 PM
Gtaste's Avatar
For the sake of others, change your tires.. ..
Before hurting someone else. Don't tell me you drive a 35k car and still nick pick about couple of hundred bucks?
Old Jul 13, 2004 | 12:06 PM
hoshtaylor's Avatar
Re: For the sake of others, change your tires.. ..
I've already bought the tires...so that's not the issue. It's just a pain in the *** to find the time to go get them swapped out. Just want to know if I can wait a couple weeks to do it when I have time or if I need to swap them out immediately...
- Homer Simpson
Old Jul 13, 2004 | 04:31 PM
Msedanman's Avatar
O.F. Administrator
From what I've learned over the years, the limit of usefulness is measured by those wear bars (little nubs in the treads). Once the tread gets that low, you're down to about 3/32" (approx. 2mm).
So you'll have to decide if your tires are ok to use for now. Personally, I wouldn't be going 90 or 100 on tires that are nearing replacement. But that's just me.
G/L
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
obender66
18 Inch
Mar 13, 2016 12:20 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
smokey2
Aug 14, 2015 03:07 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
