Inflation sensors??
Old Jul 12, 2004 | 02:20 PM
Catatafish's Avatar
Re: Inflation sensors??
They are a unit extension connected to the valve stem extended inside of the tire. If your new wheel will even accept them is what you first need to know. Many will not.
You will have to have someone that knows how to work with these things remove them from inside of the old tire, rebalance the old tire if you want to keep the old tire on the old wheel, then put them in the new wheel/tire. There is one in each wheel, and a central unit under your glove box that reads their signals.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats
Old Jul 12, 2004 | 02:55 PM
GZire's Avatar
This has some good info on the inflation sensor;
http://www.6mt.net/forum/topic.asp?T...earchTerms=tps
<P ID="edit"><FONT class="small"><EM>Edited by GZire on 07/12/04 11:55 AM.</EM></FONT></P>
Old Jul 12, 2004 | 07:32 PM
dave's Avatar
No, the low tire pressure light will not be on all the time. But it will turn on after driving for 30-45 minutes. It turns back off when you turn the car off and turn it back on.
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Jul 12, 2004 | 11:33 PM
GZire's Avatar
If I recall correctly the pressure monitors are speed dependent, so if you are not going fast enough, the pressure monitors should not come on.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
