dealing with a low car
Old May 16, 2009 | 09:43 AM
gary c's Avatar
Originally Posted by alphamatt
do you have the sport bumper? if not, cover the bruises with an OEM Lip.
Alphamatt has a great idea, you could just cover the scratches with touch up paint (Infiniti) but the lip will elongate the profile of your coupe and make it look even better. They come already painted so all you gotta do is install. Best place to order, two choices www.everythingG35.com or Riverside Infiniti ask for Tony 1-800-919-8130 they're both sponsors and give us major discounts....
Gary
Old May 16, 2009 | 09:59 AM
[Rush]'s Avatar
G35 6MT
Like everyone else has already said, it's a matter of being ready to be cautious -- and when you do come across something that looks like it might result in a scrape, slow down and go at it at an angle. Both my driveway and my parents' driveway are pretty steep, and I have the Data System Illusion front lip (which sticks out front a lil' farther than the OEM lip) -- but I don't scrape.
Also, make sure you take the time to teach yourself where the front of the car is. Practice on the side of your driveway, where it turns into grass -- and see how close you can get the front of you car to the grassline without going over. If you learn where the front of your car is, you'll avoid effing up the front bumper and/or lip by not pulling too far forward and smacking the bumper/lip into curbs and median-thingies when parking.
I'm planning on lowering my car about an inch in the future. I think that's about as far as I can go with the driveways I have to deal with on a daily basis.
Old May 16, 2009 | 12:13 PM
mdl66's Avatar
Another thing to look out for.
Driveways that are "broken up" by a sidewalk.
That is, one where there is an asphalt slope,(approx. 3 ft in length) rising 1 ft in height from street level to "sidewalk level", then the flat sidewalk,(approx. 3 ft wide),then the continuation of the sloped driveway.
If I go up the slope from the street to the sidewalk level, the front clears, but if I continue, the underside of my car hits the edge of the (bump created by the) sidewalk.
I can't get up this driveway.
Old May 16, 2009 | 01:21 PM
eurodre's Avatar
eh stock height not much to worry about, just angle it and you're good
Old May 18, 2009 | 03:44 PM
microsnook's Avatar
O HELLA OEM I LOVE your wheels. what kind are they and everything?
thanks
Old May 18, 2009 | 04:00 PM
j 4 lD's Avatar
Jacking up the car will become a b1tch if it's low enough. My low profile floor jack can't get underneath some parts of my friends lowered TL and we had to drive it up on wood, etc. Make sure you drive slowly over uneven road and avoid potholes. Also, map out where you are going so you don't end up having to go into some parking lot that has a steep driveway entrace. But most importantly, get this and put it on your car:
Old May 18, 2009 | 04:04 PM
O HELLA OEM's Avatar
thanks
thanks man
there charcoal 19" Tenzo Type M's
i got them from a vendor on here
don@tireoption
Old May 18, 2009 | 07:09 PM
eurodre's Avatar
drive the car up some wood, put jack under, you're good
Old May 22, 2009 | 06:23 AM
mmmk's Avatar
my car is lowered on 350z s-techs. i have the stock oem lip...it never scratches over speed bumps or anything. only the mid section of my exhaust scrapes over large speed bumps. hope that helps.
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
wojowojo16
Jul 27, 2015 09:57 AM
Kal Hamm
Jul 24, 2015 08:55 AM
ClwMike
Jul 23, 2015 12:55 PM
