Power Seat, Dome Light, Door Light etc not working anymore
Old May 17, 2009 | 12:05 AM
xplosive9z's Avatar
Exclamation Power Seat, Dome Light, Door Light etc not working anymore
Hey whts up guys..
I have an 08 G35xS and today i tried replacing my vanity mirror light with a de3175 LED.. i took the stock bulb out and tried putting the LED in it's place.. the LED lit up for 2 secs and when i tried to fit it into the holder, it turned off.. i figured the lights just turn off after a while so didnt pay any mind to it.. the LED didnt end up fitting in the stock holder because it was too short so i just put the stock bulb back... went upstairs, came back to my car after an hour and got it the driver seat...
the driver memory seat did not adjust to my setting, nor did the steering column go down.. the map lights dont work, the door lights dont work, the side mirrors dont work, the auto function on my windows dont work (i have to hold the switch up/down).. the audio steering controls work though however.. everything else works fine (navi, ac etc)... also i noticed under the settings for comfort and convienience, the option for "lift steering wheel on exit/entry" is not there anymore.. i checked the 10A fuse for electrical parts underneath the driver side, i also checked the one by the battery.. i disconnected the batery for 30 seconds.. still doesnt work..
what happened.. and what do i do??
Old May 17, 2009 | 02:57 AM
mysterymann's Avatar
Fuses? idk
I don't know what to do
Old May 17, 2009 | 01:00 PM
xplosive9z's Avatar
Well.. I'm taking it to the dealer tmrw.. Just wondering if pulling the battery for a good 10-15 mins would work?
Old May 17, 2009 | 03:39 PM
xplosive9z's Avatar
just to make it more specific... this was the LED that i tried putting in
http://www.v-leds.com/Interior-LED/D...54410-1-2.html
Old May 17, 2009 | 03:40 PM
t7n7's Avatar
dont' sweat it... your fuse went out... most likely because the led bulb had a short circuit in it or something causing your fuse to blow... just replace it.. maybe like 50 cents...
and don't pull the battery for any reason, you will just cause bigger headaches... since that will end up resetting your headunit (depending on model) and you will need to enter the password.
Old May 17, 2009 | 03:42 PM
xplosive9z's Avatar
which fuse though? i replaced the electrical parts 10A fuse underneath the driver panel already.. that didnt work..
Old May 17, 2009 | 03:43 PM
t7n7's Avatar
next time, try this stuff: http://www.superbrightleds.com/festoon.html
and if you REALLY want to light up your car, get this:
http://cgi.ebay.ca/1-PC-BRIGHTEST-50W-WATT-HIGH-POWER-WHITE-LED-3500-Lumen_W0QQitemZ370098352579QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item370098352579&_trksid=p3286.c0.m14&_trkparms=72%3A1215%7C66%3A2%7C65%3A12%7C39%3A2%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A24
THAT ONE led is brighter then your HID lights!!!! insane huh? ..
Old May 17, 2009 | 03:44 PM
t7n7's Avatar
i don't know your car wiring diagram but there should be a main fuse.... take it to the dealership but don't let them charge you insane amounts of money as its 99% a fuse which is less then a dollar.
Old May 17, 2009 | 03:45 PM
t7n7's Avatar
if you have a test light, you can easily test all your fuses.....
Old May 17, 2009 | 03:48 PM
xplosive9z's Avatar
yea i dont have a test light... but thats what i figured too.. probably a fuse.. i just hope they dont give me any problems with my V1 wire hooked up to the cigarette adapter fuse..
Old May 18, 2009 | 01:58 AM
Shasta Mcnasty's Avatar
You blew a fuse. Don't even waste your time going to the dealership. Same thing happened to me. Take it to any Autozone or Kragen and tell them you blew a fuse and you need to replace it. They will help you out most definitely.
Old May 18, 2009 | 08:11 AM
xplosive9z's Avatar
McNasty.. I replaced the electrical parts 10A fuse underneath the driver's side.. That didn't solve it.. You wouldn't happen to know which fuse to check?
Old May 18, 2009 | 09:07 AM
xplosive9z's Avatar
Well i posted that while i was driving.. car is at the dealer now, got 37 loaner
mike730
Jan 12, 2018 04:25 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
wonderizm
Sep 24, 2015 03:09 AM
