Window Rattle!?!?!?
Window Rattle!?!?!?
Hey guys.. just wondering if any of you have a similar problem. My widow makes a rattle/crackling sound when it is half way down and driving over small bumps.. I tested it with the door open and shook the window a bit and makes the same noise.. i doubt my window is cracked. Is there a TSB for this? I might have closed the door once with the battery disconnected but don't think I damaged the window..
ne suggestions woudl be appreciated.. thnx
Re: Window Rattle!?!?!?
I think this is a fairly common problem. My Coupe had the same symptoms and the dealer knew about the fix (there is a TSB). They told me that they had applied a heavy grease to the window slide mechanism but I think they probably did something more like the TSB described. In any case the problem has not come back since then (9 months).
Just curious, what year is your car? I would think that Infiniti had worked this bug out by now.
When I die I want to go quietly in my sleep, like my grandmother. Not screaming in fear like the passengers in her car.
Mines has the same problem. I give up on Infiniti service at my dealership.....bunch of retards. Gotta take the damn car in atleast 3 times for them to fix anything. On top of that I feel like they dont give a damn about me or my problems.
04 6MT, Black, Aero, Prem, Tein Flex's, Cusco sways, 19" SSR Sovereign's, Clears, 350Z Pedals, No front plate!
I had the same problem and it appears to be fixed. I also had them take care of the grease streak while they were in there and I think the new grease is either making a new streak or I have to clean that squeegie thing.
Word of advice that helped when I brought it in for the second time because they did not hear the rattle the first time: Do not say the window rattles, use the term in the TSB of either "pop" or "tick" (hell, use both). That way they will use those terms in searching for the TSB and find the right one.
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
