Locked myself out of my car. How do i open the car with the valet key?
Old May 23, 2009 | 06:32 PM
  #46
infinus's Avatar
The intelligent key fobs are expensive, the regular fobs you can buy for cheap on ebay and you can program them yourself. My brother used to have tons of em from when he worked at the dealer.
Old May 23, 2009 | 06:38 PM
  #47
frozenmango's Avatar
you make it sound very easy to do. is there a DIY on how to do this?
Old May 23, 2009 | 06:42 PM
  #48
infinus's Avatar
KEY FOB SETUP
1. Close all doors
2. Insert key into and remove it from ignition key cylinder more then six times within 10 seconds. (Hazard warning lamps will then flash twice.)
Note: Withdraw key completely from ignition key cylinder each time.
If Procedure is performed too fast, system will not enter registration mode.
3. Insert key into ignition key cylinder and turn to ACC position
4. Push any button on key fob once. (Hazard warning lamps will then flash twice.)
5. Do you want to enter any additional key fob id codes? If No - Go to step 9 , if Yes - Go on to next step (6)
Note: A maximum five ID codes can be entered. If more then five ID codes are entered, the oldest ID code will be erased.
6. Unlock the door, then lock again with lock/unlock switch driver side (in power window main switch).
Note: Operate this procedure even if the door is in an unlock state.
7. Push any button on key fob once. (Hazard warning lamp will then flash twice.)
At this time, The oldest ID code is erased and the new ID code is entered.
8. For additional key fobs do steps 6 thru 7.
9. Open driver side door. (END)
After entering ID code, check operation of remote keyless entry system.
Old May 23, 2009 | 06:45 PM
  #49
t7n7's Avatar
no no , i'm talking about internally heh.. like inside the door, i'm gonna block the metal thing so the cloth hanger can't hook on to it....
also, OP, WTF man.. u locked yourself out again? Get your *** to a local locksmith, program an extra key and buy an extra keyfob. in fact, if you really want to go cheap, buy a 30$ alarm kit off ebay, but dno't use it as an alarm, just use it to unlock your car, it will not only be cheaper then a factory keyfob, it will give you an extra 2 keyfobs, and better range!!!
now go and do that lol..
Old May 23, 2009 | 06:58 PM
  #50
thanks for your concern and yes im in the process of getting an additional fob..
Old May 23, 2009 | 07:02 PM
  #51
KEY FOB SETUP
1. Close all doors
so i have to reprogram my original fob first then my additional fob in step 6 correct?
Old May 23, 2009 | 07:14 PM
  #52
infinus's Avatar
I think you have to program them all at once if Im not mistaken but which one you do first shouldnt matter since it will clear both.
Old May 23, 2009 | 07:18 PM
  #53
dineth00i30's Avatar
wut? ur original one is already programmed. if you get a new one like let say from ebay, then thats the procedure to program the new one. at least thats what i think.
Old May 23, 2009 | 07:40 PM
  #54
gotcha, found one on ebay for 20 beans. thanks
chinee
Jun 10, 2024 07:48 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
apintojr
Jul 23, 2015 10:52 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
