weird window issue.
Old May 28, 2009 | 03:27 PM
TofuProductions's Avatar
weird window issue.
Whenever I have my windows down (whether it be all the way down or partially) as you all know our cars have two settings, the halfway point where you can roll it down and it stops whenever you let off the switch, or where you push it down all the way and it rolls down by itself all the way.
whenever I choose to roll up my window in the (full auto up) setting, which would be when I pull it up all the way and not partially for the window to go up by itself, it will roll up all the way, then it will lower itself down again but only about 3 inches and stop.
It only does this on my passenger side, any ideas why? and how to eliminate this? Its a tad bit annoying..
Thanks!
Old May 28, 2009 | 04:55 PM
pwebb's Avatar
this has been beaten to death.
you need to re-time your window. search, and you will find the procedure.
if you cannot get it timed, you will need a new window motor.
you can try taking it apart and cleaning the motor out. a member posted his success with this.
Dallsinghjr1
Sep 17, 2023 11:25 AM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
