Confirm a few things a noob thinks he has figured out? (long)
Old Jun 5, 2009 | 01:48 PM
LightsOut's Avatar
SIETESG
08 sedans are HR motors they have two air boxes.
so no a Z tube wont fit
Old Jun 5, 2009 | 01:55 PM
smr514's Avatar
noted!
Old Jun 5, 2009 | 06:41 PM
partyman66's Avatar
Originally Posted by DiGil
From what I hear you might not want to discount the '06 airbox. I believe it comes in '05 coupes as well since I have one. Basically it adds a velocity stack to increase flow. The design was changed for a reason.
Could you snap a picture of where the velocity stack is on your airbox? I was just looking around on cardomain for pictures of the airbox from '06+ 6MT G35 Coupes, and the outside of the airbox looks pretty much the same as the '03 and '04 Coupes. It's not that I doubt what you're saying, I'm just curious to see the design. I would assume that for the velocity stack to do anything, it would have to be inside the airbox on the clean side of the filter.
For example... this picture is from an '07 G35 Coupe 6MT:
And this is from an '04 G35 Coupe 6MT Airbox:
Those 2 airboxes and intake setups look pretty much identical to me in every way... at least from the exterior.
Old Jun 5, 2009 | 06:57 PM
Uda880's Avatar
You have over 1.5K posts, and don't know what it is? I hope you're being sarcastic.
https://g35driver.com/forums/intake-...06-airbox.html
Old Jun 5, 2009 | 07:43 PM
LightsOut's Avatar
SIETESG
the V stack is behind the drop in filter thats why you dont see it.
V stack is in all 05+ 6mt
just purchase it from riverside infiniti for 40 bucks.. well worth it
Old Jun 5, 2009 | 07:50 PM
blaccG35's Avatar
^40 bucks??? got a link??
Old Jun 5, 2009 | 07:53 PM
LightsOut's Avatar
SIETESG
call riverside infiniti or look it up at everythingg35.com under oem replacement parts.
but look under 05 or 06 6mt air box. they have different part numbers..
ill try and do a search for you.
Old Jun 5, 2009 | 08:10 PM
elayman's Avatar
get the 5/16th spacer.. there have been dyno tested gains of around 11hp. the popcharger and ztube don't gain much but sound cool (I'd recommend a stillen airbox b/c it has a way better heat shield than the popcharger) exhaust is also for sound, but can add a couple hp if you have the right setup
Old Jun 5, 2009 | 08:12 PM
155Mph's Avatar
Originally Posted by uda880
you have over 1.5k posts, and don't know what it is? I hope you're being sarcastic.
Old Jun 5, 2009 | 08:43 PM
Uda880's Avatar
I'm thinking about getting one.
rezendvous420
May 31, 2020 01:26 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
tiguy99
Jul 26, 2015 01:39 PM
Karnicle
Jul 23, 2015 05:08 AM
