Look what I did yesterday (VSS-bypass)
Old Jun 9, 2009 | 02:18 PM
seymore4's Avatar
m56
Originally Posted by bigc
https://g35driver.com/forums/audio-v...oving-diy.html
if you've changed your in-cabin microfilter then you know how to get to the navigation system harness.
Pretty much how you do it
I like my switch better tho
Old Jun 9, 2009 | 02:23 PM
seymore4's Avatar
m56
Originally Posted by TootsieRoll7
Nice. So do you just add the switch on to the wire in series? I am so doing this for my nav system.
The way the NAV works is that when you're moving power is sent through the VSS wire to the NAV to tell it to lock you out. When you're stopped there is no power. So by cutting the wire and putting the switch between the sender and the receiver you can control if the signal gets through and make the NAV think you're sitting still whenever you want.
Old Jun 9, 2009 | 03:11 PM
cc1012's Avatar
do you think i could use a connector like this?
http://www.radioshack.com/product/in...ductId=2104093
i really dont want to have to start cutting up my harness
Old Jun 9, 2009 | 03:28 PM
seymore4's Avatar
m56
Well you have to cut it anyways... In order for this to work you have to physically cut the wire in half and connect each side to the switch so that the switch can interrupt the signal.
If you're going to use one of those connectors go with the smaller one (red I think) and then tape it up with electrical tape.
The vss wire is really small and blue won't hold it.
Old Jun 9, 2009 | 04:12 PM
Ryosen11's Avatar
Nice!
I'll do this when I change my cabin filter soon!
Old Jun 9, 2009 | 06:31 PM
seymore4's Avatar
m56
If you have any questions let me know-
Old Jun 10, 2009 | 03:07 AM
TootsieRoll7's Avatar
seymore4 -- Are you planning on shortening the wires? I hate having to bundles wires together IMO. Unless it's a 700 Watt power supply for my micro ATX computer case
Old Jun 10, 2009 | 03:20 AM
seymore4's Avatar
m56
Yeah I didn't realize how much extra wire I actually had till I had it all put together
I just ziptied it all together and left it there. It's not hurting anything hidden behind the panel and if I ever need to remove the center console I have some slack in the wire so I don't have to remove the switch and rewire it.
But I totally understand how you wouldn't like it
Old Jun 10, 2009 | 02:05 PM
cc1012's Avatar
and what gauge wire did you use?
Old Jun 10, 2009 | 02:08 PM
seymore4's Avatar
m56
I don't know... I didn't feel like going back to the store so I just used some extra speaker wire I had laying around
Old Jun 10, 2009 | 06:18 PM
lol sounds like winging it as you go. I like that. Make me feeling I created a new mod
Old Jun 10, 2009 | 10:11 PM
seymore4's Avatar
m56
Hahaha yeah I had the switch and understood the general concept LOL
But the rest was mainly "I should be able to..."
Old Jun 10, 2009 | 10:42 PM
Cubanl81's Avatar
You are the man Seymore. Thank ya thank ya thank ya lol. One of the most annoying things about the nav. Cheap DIY FTW.
Marlin84
Apr 1, 2020 12:52 PM
Crisci33
Jun 29, 2017 08:31 AM
Fox843
Nov 7, 2015 05:43 PM
vQFamily
Sep 30, 2015 01:17 PM
mattdg35
Sep 14, 2015 11:28 AM
