loud clicking sound from passenger window!
Old Jun 16, 2009 | 08:51 AM
aBLUEg35's Avatar
so ive searched for about an hour now and i cant find what this is so sorry if this is a repost!
My passenger window make a very loud clicking sound sometimes when i roll it up, what can this be?? i just dont want anything to break. its an 06 coupe with 21,000mi can anyone help please!!!
Old Jun 16, 2009 | 09:28 AM
parhamm1's Avatar
I have the same issue and would be curious if anyone knows what the problem is caused by.
Old Jun 16, 2009 | 10:57 AM
cruzmisl's Avatar
Does the click sound like it's coming from the glass or the arm that moves the window up? Have you taken off the door panel to see what's going on when you roll the window up?
Old Jun 16, 2009 | 12:05 PM
cruzmisl's Avatar
FWIW, this is a common problem on 3 series BMW coupes as well.
Something about that long door, heavy window, and stupid plastic pieces in important places.
Old Jun 16, 2009 | 03:33 PM
aBLUEg35's Avatar
it sounds almost like the glass itself is hitting something up top! its just one very loud click when the window is about a half inch from the top, and sounds almost like getting a chip on the windshield on the highway.. ive tried to watch while it rolls up but i cant see anything noticable
aBLUEg35's Avatar
ps thanks for all the help!
Old Jul 18, 2009 | 10:28 AM
aBLUEg35's Avatar
it was only once in awhile. now its doing it almosteverytime..
Old Jul 24, 2009 | 08:43 PM
jinjohn26's Avatar
mine is coming from my rear tires, what could it be?
Old Nov 6, 2010 | 06:22 PM
aBLUEg35's Avatar
this is a different thing all together than the axle click... this is a window. anyone have any ideas? i still havnt figured it out. thanks guys
Old Nov 6, 2010 | 06:36 PM
the_sedan's Avatar
the window regulator mounting bolts tend to come loose so take the door panel off and make sure they are tight. then remove the 3 stickers that cover the window glass mounting bolts and make sure they are tight. reset your limit switch....search, i put a thread up about it. and if it still does it then id suspect your regulator is bad....?
Old Nov 6, 2010 | 08:12 PM
N80's Avatar
N80
Mine does this too, driver's side. Very intermittent. I really don't want to pull the door panel off. I've repaired the power windows on my old Pathfinder (p.i.t.a.). Is there a DIY for getting the door panel off, I don't want to mess anything up cosmetically?
What is the risk of doing nothing?
Old Nov 6, 2010 | 08:37 PM
the_sedan's Avatar
if its the regulator bolts, and you do nothing....they fall out, the regulator is loose and binds up then eventually gets jammed up with either the glass or another piece of it. resulting in................a new regulator!
theres a bolt cover in the pocket where the door handle is. 10mm bolt there. there are 2 more bolts behind the pull handle cover....the long silver piece. take a small screwdriver and you'll see small openings on the side.....pop it loose from there and it will unsnap. then all you do is pull the door panel off as its held in with plastic clips all around. pull up to get it off the actual door frame then towards you. disconnect the step light connector, the switch connector and the door lock/latch cables. then tighten all the bolts you see....all 10mm.
Old Nov 6, 2010 | 09:39 PM
N80's Avatar
N80
Excellent. Thank you very much!
Old Nov 9, 2010 | 11:33 AM
Oceanbound's Avatar
This is why i have to "ration" how many times i roll the windows up and down
Old Nov 9, 2010 | 11:44 AM
N80's Avatar
N80
I like driving this car with the windows down. I love to listen to the exhaust.....plus, the wind rushing in covers up all the interior squeaks and rattles. Win/win.
So, I'm going to fix mine tomorrow or this weekend. It is only on the driver window and doesn't happen much but it sounds easy to fix and expensive if the regulator gets messed up.
