Lowering info...
Old Jul 11, 2009 | 03:51 PM
| 1cleanG |'s Avatar
Originally Posted by twalls
Yeah.. went to NTB to get alignment.. and they warranty their work for 6 months.. So I'm going back in another month or so to ensure that it's still w/in spec range.. They actually have a readout that will tell you via computer if your car requires a camber kit.. When I got my first alignment done after the spring intall (waited a week to let them settle) The computer said no extra hard ware was needed..
The NF210s are so close to stock spring rates, that's why I got them.. They're even marketed to not need any extra hardware.. They're not extreme and don't lower your car more than an 1". W/ 20s you can get away w/ a very conservativev drop (just enough to fill the wheel well) and it looks great.. But you don't need all the extra hardware... If you go down to 19s you might still need to lower more, but w/ 20s you're fine..
^^great advice. My buddy just put NF210's on his g37 for the exact same reason. He bought the car brand new, put 20's on it, and dropped it, looks perrrrfect. Also aligned up without a kit. This is one of the best even stance you can get for having a "mild drop".
I also know others that have had Teins (both S and H). I've heard you can try and align your H-tech's CLOSE to stock camber, but S you most definitely need a camber kit.
PS...you lie when you say you searched and couldn't find anything or you def didn't look very hard...when looking for my right suspension I found mAAAAAAAny forums and photos and side by side b4's and afters. ...but none the less we're here to help
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
