350z springs drop on g35
Old Jul 30, 2009 | 02:36 AM
av8or's Avatar
is it correct that a '06 350z springs and shocks on a g35 coupe will drop it a good inch front and back? right now i have 20's and have a 2 finger gap between the fender and tires, tanabe nf210 gives an inch drop up front and .06 at the back... should i go with oem 350z springs or just get the tanabe? as far as camber, which one has the least impact?
Old Jul 30, 2009 | 02:40 AM
SDGenius's Avatar
no, not true only 1/2" drop
Last edited by SDGenius; Jul 30, 2009 at 02:28 PM. Reason: ment 1/2 not 1/5, sorry
Old Jul 30, 2009 | 02:42 AM
av8or's Avatar
i should go with tanabe then? 1/5 is not really a noticable drop right?
Old Jul 30, 2009 | 03:24 AM
fresh_06'G35's Avatar
hardly noticeable yes, also will have a lesser impact on camber. the lower you go the more negative itll be.
Old Jul 30, 2009 | 10:57 AM
TofuProductions's Avatar
I have it on my car, its noticable if you've seen the drop before. but maybe not to the untrained eye. (my fiancee noticed it though at first glance).
I'd love to drop it more and maybe spend a bit more on camber kit, but with the roads here in Chicago??.. yeah no thanks.
Old Jul 30, 2009 | 11:05 AM
tragedycat's Avatar
That will not give you the drop you're looking for, in fact it will hardly lower your car at all.
I'd go with the Tanabe's you're looking at instead. As far as camber, the more you drop the more negative camber you'll incur. With the Tanabe's, I'd count on getting front and rear camber kits. You may get away without one, but you should budget them in your total regardless.
Old Jul 30, 2009 | 02:29 PM
SDGenius's Avatar
do you have a coupe or sedan???
Old Jul 30, 2009 | 02:30 PM
av8or's Avatar
right now i can fit 2 fingers between the fender and wheels... to those that have the Z33 on their g35, how many fingers can you fit? just to give me an idea on the drop.. and i drive a coupe
Old Aug 1, 2009 | 02:52 AM
av8or's Avatar
went ahead and got the tanabe nf210... 1" drop in the front and .06" rears... 1 finger clearance between all fenders and tires..
Old Oct 26, 2009 | 07:35 AM
joesmithf1's Avatar
hi, i m planning to get the nf210 too, but concern about impact on the camber. How's your tire wear so far, and do you have camber kit? i appreciate any feedbacks.
Old Oct 26, 2009 | 07:46 AM
av8or's Avatar
you'll definitely need a camber kit for fronts and rears... it's not that bad but unless you like spending money on tires.. right now i'm just doing the rears...
Old Oct 26, 2009 | 07:27 PM
blaccG35's Avatar
if your looking to make it a even drop, you can always do the springmount mod. It will looks 100x times bettter
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
