I NEED A FIX!!!
Old Jul 29, 2004 | 01:06 AM
Aldo420's Avatar
I NEED A FIX!!!
Hey whats up guys i havent posted in a while but i have no one else to turn to... I have been through 2 front bumpers and 2 sets of spaslh guards my car bottoms out everywhere i added 19inch wheels with bigger tires it raised it a bit but not enough... I live in tallahassee florida the hills here are huge... I need to get my car atleast 1 more inch off the ground to trully be able to drive comfortable... since the front and rear tires are so seperated when i go over the extremely poorly constucted speed bumps all over tally... the car hits bottom.. everytime i enter my neighbor hood im swarving around just so i wont hit.. i have gone through 3 neon kits and just an all out mess all this money coulda of gone to mods! anyhow enough of my yap....
What can i do to fix it (raise up at least in the back)without messing up the cars suspension...
Will coil overs work ?
Also has anyone tried to put a remote start system into there cars ?
Thankyou
Old Jul 29, 2004 | 03:24 AM
Aznteazer's Avatar
Re: I NEED A FIX!!!
if u're having that much problems, just put it back to stock suspension, and the neon kits back in the box.
Old Jul 29, 2004 | 03:32 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: I NEED A FIX!!!
It's karma for putting neon kits on a G.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old Jul 31, 2004 | 01:47 PM
Aldo420's Avatar
Re: I NEED A FIX!!!
its on stock suspension.... right now..
Old Aug 3, 2004 | 06:11 PM
Aldo420's Avatar
Re: I NEED A FIX!!!
so can anyone help or im pretty much screwed ?
Old Aug 3, 2004 | 06:48 PM
ozracer01's Avatar
Re: I NEED A FIX!!!
I'd suggest that you leave off the Neons...permanently. I'm not quite understanding how your car is rubbing, even after installing 19's. That should've raised your car if your still running stock suspension. Not sure what else you could do. Maybe go slanted over speed bumps and into driveways, this is somehting i always do, altho not needed because I never rub anyway, but just a precaution.
Old Aug 3, 2004 | 07:56 PM
NovaJay's Avatar
Re: I NEED A FIX!!!
I think I have your fix:
1. Remove the neons from your G35.
2. Sell your G35.
3. Buy a Civic.
3. Install the neons on the Civic.
[img]/w3timages/icons/smile.gif[/img]
'04 G35 Coupe DG/G/5AT/Premium.
Old Aug 3, 2004 | 08:01 PM
Q45tech's Avatar
Re: I NEED A FIX!!!
Raising the ride static height has all the camber change problems of lowering . Are your 19" tires the correct diameter to meet oem?
Jack hammer or front in loader to fix speed bumps.
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
NyCrAzY
Oct 1, 2015 09:19 AM
