30k maintenance question
Old Sep 1, 2009 | 11:51 AM
rob40wilson03's Avatar
i am taking my car in today for the 30K maintenance (i have already been through the threads and excluded a few things from the list)
my question is: should i have them change the transmission fluid?
i want to put in a different fluid (people have recommended amsoil) and i can do it myself BUT im afraid that if any transmission problems arise later, they will try to tell me that since i opted out of it at the 30K service, that they wont fix it under warranty
so i was thinking maybe just let them replace it, and then do it myself later on.... which would effectively act as a fluid flush
what do you guys suggest?
Old Sep 1, 2009 | 01:01 PM
Knoxrower's Avatar
Replacing the trans fluid is called for only under the "Premium Maintenance". There's no need for it at 30k and it won't void your warranty if you pass.
Old Sep 1, 2009 | 01:21 PM
LightsOut's Avatar
SIETESG
suggest just do an oil change, check your air filter and change your cabin filter.
Old Sep 1, 2009 | 01:35 PM
6mt-driver's Avatar
You also may want to swap out the clutch fluid. I'm around 30k and just did that b/c it was a little murky. Took 15 min. Just buy a turkey baster and can of DOT3 brake fluid. The clutch pedal is a little smoother now, so I'd recommend it.
DIY:
https://g35driver.com/forums/drivetr...me-here-2.html
Old Sep 2, 2009 | 02:30 AM
kiantech's Avatar
DIY:
Use dot4...its better for higher heat
Old Sep 2, 2009 | 01:53 PM
clarkkent06's Avatar
Definitely. It's not like it's much more expensive or anything. Just DO NOT use DOT5
Old Sep 3, 2009 | 04:41 PM
well they ended up replacing my clutch master cylinder so they replaced the fluid too.... all under warranty
Old Sep 3, 2009 | 05:11 PM
LightsOut's Avatar
SIETESG
why did they do warranty work if you only went in for 30k
Old Sep 4, 2009 | 12:11 AM
Black Acc's Avatar
I just recently hit 30k too, do I really need to change the fuilds or can I wait? When is it really suppose to be changed?
Old Sep 4, 2009 | 12:33 AM
gary c's Avatar
Are you aware you don't need to go to Infiniti for the 30K maintenance? I had mine done at Nissan after 25K miles because I've had
my '04 for 5 years, more of a time thing rather than mileage. All fluids changed, incl. a tranny flush for just over $200, Infiniti wanted twice that
for the same work....Infiniti dealerships.
Gary
Old Sep 4, 2009 | 01:14 PM
cause the clutch pedal was sticking sometimes.... i told them how I had read online (this forum) that the master cylinders sometimes develop an internal leak.... i told them that, hoping they would just go ahead and replace it with a new one.... and they did
Old Sep 4, 2009 | 01:17 PM
the clutch fluid should be changed more often than infiniti recommends.... it's easy, you can do it yourself
check your fluid, if it's anything other than clear and SLIGHTLY colored, it should be replaced
to do it, get a cheap syringe from walmart, suck out the fluid from the reservoir, replace it with DOT4 synthetic brake fluid, pump the clutch about 20 times, suck out the fluid and fill it up again with new fluid.... repeat this as necessary until the fluid is nice and clear after pumping the clutch
Old Sep 4, 2009 | 01:51 PM
^yup, for sure.
A lot of people use this method (it's also a good read)
http://rangeracceleration.com/Clutch_Care.html
Old Sep 4, 2009 | 04:23 PM
bocatrip's Avatar
Change Engine Oil, Change air filter if needed and call it a day.
Old Sep 4, 2009 | 04:55 PM
infinitisport's Avatar
had somethin similar happen to me once,
went to the mall and pikd up some hoe, tookd her for a ride,
next morning the car was fine,
somethin to try...
Gip
Aug 24, 2015 05:31 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Mac8008
Aug 4, 2015 09:19 PM
korfak
Jul 20, 2015 12:10 PM
