changed oil for the first time...
Old Sep 7, 2009 | 02:06 PM
CLEANBS's Avatar
I cant read the dipstick
so I just put the whole 4.73 quarts from the walmart jug in
should I be okay?
Old Sep 7, 2009 | 02:17 PM
JOKER's Avatar
CLUB MODERATOR
why cant you read the dip stick?
Old Sep 7, 2009 | 02:18 PM
fresh_06'G35's Avatar
the dipsticks in these cars suck, if u wanna get a decent reading you gotta wait like 10 mins after pouring the oil. im sure your pretty good but the car should have 5qts. in it.
Old Sep 7, 2009 | 02:19 PM
CLEANBS's Avatar
its my first time reading a dipstick lol
is there a wiki or doc on the net for reading these dipsticks?
Old Sep 7, 2009 | 02:21 PM
JOKER's Avatar
CLUB MODERATOR
http://autorepair.about.com/od/regul...a/checkoil.htm
Old Sep 7, 2009 | 03:01 PM
CLEANBS's Avatar
thanks joker
looks like the oil is just barely touching the H mark
Old Sep 7, 2009 | 04:00 PM
BlackGGG1986's Avatar
Congrads
Old Sep 7, 2009 | 04:12 PM
CLEANBS's Avatar
Originally Posted by BlackGGG1986
Congrads
well i kind of messed up by using a Fram tough guard oil filter
i forgot to research filters
Old Sep 8, 2009 | 12:19 PM
CLEANBS's Avatar
i just checked oil again this morning
the oil is covering the H mark now no higher, ( i checked a couple times and got this result)
is it okay if its just a little too high?
Old Sep 8, 2009 | 04:22 PM
code2424's Avatar
If you wanna get a good reading with the dipstick check your reading in the morning when the car is cooled and not been started it's very easy to read at that time. I believe you meant 5 quartz and 4.73L thats what it says on the jug. You should be fine if you put the whole jug in. Next time use mobile 1 oil and mobil 1 filter if you want your car to last longer. I always use Mobil 1 extended performance oil and filter costs like few bucks more than the mobil 1 original.
Old Sep 8, 2009 | 04:59 PM
LightsOut's Avatar
SIETESG
mobil 1 is not full syn.
Castro FTW.
Old Sep 8, 2009 | 05:06 PM
Swivel's Avatar
Moderator
Good for you, Detroit. DIY FTW.
Old Sep 8, 2009 | 05:22 PM
joedaddy1's Avatar
because if you use a regular conventional oil, your car will not last as long right? :eeps:
Old Sep 8, 2009 | 05:24 PM
partyman66's Avatar
Castro FTW.
Castrol isn't either unless you get the German Castrol.
Old Sep 8, 2009 | 05:27 PM
LightsOut's Avatar
SIETESG
tell you the truth Im not sure if Castro syn is full or not, but I still prefer it over mobil 1.
but German oil is what I meant to post at first.
JoeMac
Aug 20, 2015 10:17 AM
yassy
Aug 9, 2015 07:31 PM
ghost_g35
Aug 7, 2015 10:31 AM
ClwMike
Jul 23, 2015 12:55 PM
