which rotors should i go for???
Old Sep 16, 2009 | 02:35 AM
m3vegas's Avatar
i have to change the brakes on my g an i got the brembos so i just got the pads but im no really sure wat rotor to go wit .i was thinking stoptech rotors all around but dont no if they would crack after a while ..any suggestion ??
Old Sep 16, 2009 | 03:51 AM
code2424's Avatar
I don't see why they would crack unless you brake going 120mph or take your car to the track. Stoptech makes pretty good rotors to.
Old Sep 16, 2009 | 04:57 AM
dofu's Avatar
20 Year Member
I don't see why they would crack. The biggest reason rotors would crack is because a company took blanks and drilled them incorrectly, damaging the pillars inside, weakening the structural integrity of the rotor. Or they just drilled them incorrectly altogether. These are usually the cheap drilled rotors you find on ebay from a random brake shop that drilled the rotors themselves. "Drilled" rotors made properly are cast with the holes.
If you want to be safe, avoid drilled rotors. And if you're worried about StopTech's rep of having a few cracked rotors here and there, you have other reasonably priced options like Power Slot, Centric, Brembo, along with plenty more if you're willing to spend a good amount more.
Old Sep 16, 2009 | 08:23 AM
uf20wop's Avatar
centric blanks
Old Sep 16, 2009 | 08:40 AM
WhosUrBuddiee's Avatar
Buy the Akebono upgrade kit.
Old Sep 16, 2009 | 03:07 PM
Soopa G's Avatar
I bought a set of slotted and cross drilled rotors, with Axxis pads, off ebay..can't remember the name..for $400....I have not had any problem and they have been driven hard....I've used them for at least 6 track days..no warping or cracks....Axxis pads are **** though..got rid of those right away
Old Sep 16, 2009 | 04:05 PM
PTownG's Avatar
http://www.z1motorsports.com/350_g35...oducts_id=2123
great bang for the buck
Old Sep 17, 2009 | 12:36 AM
m3vegas's Avatar
yea ill prolly go wit stoptech....thanks guys
Old Sep 17, 2009 | 01:55 PM
Shawn87's Avatar
Ebay... rotors88
Brembo fit Drilled and Slotted with Ceramic pads, front and rear - $269US for complete set.
Never had a problem with them.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
