Oil in 2004 g35 coupe HELP !! ANYONE!
Old Sep 29, 2009 | 08:26 AM
Reezlah's Avatar
Angry Oil in 2004 g35 coupe HELP !! ANYONE!
huge problem here... i bought a 2004 g35 coupe last year.. now my engine is burning oil like a B*tch. I mean like between one oil change i've used a whole bottle of oil to top up . thats 5 quarts of oil added between a 3,500 km oil change. can SOMEONE please help me and tell me what I should do. I'm way past the warranty on my car.. so i think. Can someone please tell me if theyve gone thru this and have had to do something on their own to fix the problem.. I live in Toronto, Onatrio in Canada. Has anyone attack Infiniti past the warranty mark for this issue. please please please help. THANK YOU
Reezlah's Avatar
I just went to the dealer.. they told me i was 5,000km out of warranty and that I would have no chance of makign a claim !! SOMEONE PLEASE TELL ME WHAT TO DO !!! PLEASEE !!! i mean 5k km? thats ridiculous not to accept my warranty. SOMEONE PLEASE HELP whose goen thru this before.. who did you talk to and how did it work out or WHAT CAN I DO !!! :'(
Old Sep 29, 2009 | 08:42 AM
jwrape's Avatar
If you do a search on Oil consumption you will see, almost all the Rev up engines have this problem. I add a quart between oil changes as well. It's just something you're gonna have to monitor unless you want to replace your engine. I've learned to live with it....
Sorry...
Old Sep 29, 2009 | 08:48 AM
EL-EE-ES's Avatar
its going to be hard to get nissan/infiniti to replace your motor because you are out of warranty...let it jwrape said just monitor it or go ahead and buy a built short block
Old Sep 29, 2009 | 08:54 AM
jwrape's Avatar
When I bought mine 2 months ago, i realized i will be replacing the motor eventually. I have 120k on mine. It still runs great but you can hear it running lean sometimes right after start up and it also is not as strong right away... Gonna start running a higer octane fuel to help with the lean condition that the oil presents
Old Sep 29, 2009 | 08:55 AM
thescreensavers's Avatar
Mr.202?
Sorry...
He has an 04 no rev up. OP that sucks bad
Old Sep 29, 2009 | 08:56 AM
jwrape's Avatar
Oh well, same still applies. Just Monitor it and keep an eye out for a long block.
Old Sep 29, 2009 | 09:03 AM
Reezlah's Avatar
how much would it cost me to replace a longblock?
this is insane.. i mean 5,000 km out of warranty? really? Infiniti is that uselss to make a car engine that lasts 100,000 km? are you kidding me and now they dont want to hellp ? talk about bulls**t quality. its ridiculous.. i want to go full force and try juicing Infiniti as much as I can.. has no one really tried to do this before?
im loosing crazy amoutn of oil...
about 4 quart every 3000 KM.. not miles.. KMS!!
its insane and I put so much work into the look and body of this car you guys wont beleive .. and now this?
any more thoughts guys?
Old Sep 29, 2009 | 09:07 AM
jwrape's Avatar
I've read many threads about people pushing Infinity. If you are out of Warranty you are screwed. 4 quarts is a lot per 3000km. You prolly would be better off replacing the long block. I think it runs from $3500-$5000 depending upon the route you go. You can find a low mileage long block from a salvage yard and save a little money or you can have a block built and then you won't have this problem again, but it will cost more.
Old Sep 29, 2009 | 09:12 AM
jwrape's Avatar
Just posted https://g35driver.com/forums/engine-...or-1000-a.html
Old Sep 29, 2009 | 09:29 AM
Rostasteve's Avatar
5 quarts of oil between changes is insane! Are you sure you're not leaking oil? If you have to do an emissions test where you live, did you have any problems passing it?
I think you're screwed as far as warrantee is concerned. Since you got the car used you'll probably have a very hard proving that the previous owner did all the maintenance. It might be worth sending your oil away for analysis to blackstone to see if you have signs of engine wear.
Old Sep 29, 2009 | 10:22 AM
Deezflip's Avatar
...You prolly would be better off replacing the long block. I think it runs from $3500-$5000 depending upon the route you go. You can find a low mileage long block from a salvage yard and save a little money or you can have a block built and then you won't have this problem again, but it will cost more.
So, the longblock is the reason for oil consumption? This thread is claiming that it's the rings....would be nice to know which one is causing the OC definitely.
https://g35driver.com/forums/engine-...n-cause-3.html
Old Sep 29, 2009 | 10:25 AM
jwrape's Avatar
The rings are the issue. If you are going to fix the issue, you don't just go into a motor and only replace the rings, if you tare down a motor to the rings, you do a full rebuild. A new or newer long block would fix the issue because you are replacing the entire motor with one that doesn't have the same issue.
Old Sep 29, 2009 | 10:39 AM
Deezflip's Avatar
aight, so what you're saying is...keeping the original long block will eat up the new rings?
Old Sep 29, 2009 | 10:42 AM
TofuProductions's Avatar
your situations wasn't as bad as mine:
https://g35driver.com/forums/g35-cou...non-revup.html
I went through 5 qts of oil, every 1000 miles.
I did have warranty but to get it approved took nearly a month.
Turns out I had scoring on my piston rings, and I don't even push my car hard.
