Rim question
Old Oct 1, 2009 | 08:31 PM
KakaroT's Avatar
Rim question
So am geting this great deal on some sick *** 20" rims, i was wondering if 20" 's would look good on a G and if it would be able to be lowered? if its able to be lowered about how much Tein-S or Tein-H ?
Old Oct 1, 2009 | 08:47 PM
The Stimulation's Avatar
You can't adjust the height on springs, it's just one height drop. Yes 20's will look good, just as long as the rims themselves do. You can go with coilovers and lower the car. Keep in mind tire size makes a difference. 20's is the largest I'd go on the G.
Old Oct 1, 2009 | 08:49 PM
KakaroT's Avatar
I know u cant adjust the heaig on springs i just wanted to know what set of springs are the best for 20's the Tein S or the Tein H cuz i know the H's lower way less am not sure if the 20's will be ok when lowered on the Tein S
and thanks alot for the info
Old Oct 1, 2009 | 09:08 PM
Either one will be fine, just depends how low you want to go. I'm lowered on coilovers withi 20's so I'm sitting lower than either of those springs. Then again, my tires are stretched.
I used to have 245/35's on 20's before and I was on Tein Basics almost on the lowest setting and I was fine so I'm assuming you wouldn't have any problems at all.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
hurleyguys
18 Inch
Sep 9, 2015 12:24 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EasySausage
Jul 14, 2015 11:17 PM
