best way to ride lower
Old Oct 2, 2009 | 10:41 AM
agdarnel's Avatar
Ok so I was looking at my 04 Coupe yesterday and I think I want to go a little lower with it rather than stock but at the same time I don't want to be dragging my bumper everywhere. Any ideas on this would be fantastic. Oh and I don't want to spend a ton of money either so cheaper is better Thanks for any help!!
Old Oct 2, 2009 | 11:11 AM
agdarnel's Avatar
oh wow aight that looks pretty good. it was enough to make a difference right??
Old Oct 2, 2009 | 11:26 AM
parhamm1's Avatar
If that difference isn't enough for you then go with Tein 350z H-tech springs. That's what I'm running now and it's a perfect drop for me. Not too low, but closes the wheel gap perfectly.
Old Oct 2, 2009 | 11:39 AM
eurodre's Avatar
it all depends on what you want, close up the tire gap or get closer to the ground
why not get coilovers? because most likely you will want to go lower in the future
but you really only have two choices, springs or coilovers
Old Oct 2, 2009 | 12:11 PM
nghiars's Avatar
make sure you upgrade your shocks as well and get an alignment... if you go lower than an inch, look into getting front and rear camber kits, the cost will pay for itself by prolonging the life of your tires.
Old Oct 2, 2009 | 09:39 PM
scrillasherv's Avatar
Originally Posted by Princess_Jen
Heres mine.. I just did the 350z springs. 50 bucks.. me and a friend installed it in my garage. Once they settled in, I'm just low enough to clear all the speed bumps at angels without losing my bumper.
Did you need a camber kit? Or just an alignment? And also did you get new shocks? Thank you
Old Oct 2, 2009 | 10:16 PM
DEEZBLUBALLZ's Avatar
Does one have to get new shocks? Will the OEM ones hold up for a while?
Old Oct 2, 2009 | 10:56 PM
V35 Skyline GT's Avatar
6MT Coupe
^Hear they'll hold for awhile depending on how much drop. No personal experience though. I went the coil-over route and have never looked back.
Old Oct 2, 2009 | 11:09 PM
bigc's Avatar
Wings Nation
350z H-techs with Tokico D-spec shocks
Old Oct 3, 2009 | 01:11 AM
idrive_MD's Avatar
You can lower on 350Z springs or H-tech 350z springs and not require any camber or toe kits. I just suggest you spend the money on a quality alignment, dialed in toe settings will save your tires and your wallet.
I'm lower than 1-inch all around and I only needed a rear toe/camber kit, but my installer said he could have probably have dialed in the toe with the stock setup. He mentioned it would still wear faster than what he did do, but not nearly as bad as a half-*** attempt from some national tire store. I took my setup to a local porsche shop that also does race prep for their cars and their customers.
I was able to get 4-wheels/tires mounted, balanced, camber/toe kit installed and aligned for less than $300.
Old Oct 3, 2009 | 02:46 AM
code2424's Avatar
Do you guys have problems on pot holes and small bumps on roads those of you only lowered on springs? On my old car I lowered it not to far and going over pot holes felt like freaken car crash.
Old Oct 3, 2009 | 02:47 AM
code2424's Avatar
I would probably scrape going on speed bumps in my school. They are like twice as big as normal once.
Old Oct 3, 2009 | 03:09 AM
EndlessWaltz112's Avatar
Here's mine with Nismo S-Tune suspension and 25mm spacers all around. Its not bad to be honest. Since my car is a daily driver, its not too low or stock height in a sense. I still maneuver around potholes and such. You would have to deal with small bumps on the long run if your going to change your current set up. On mine, its stiffer than stock so you feel more bumps then the usual. Speed bumps is not a problem with this. If you really wanna spend money on some suspension though, I'd suggest some coilovers.
