slip light = funs over
Old Oct 11, 2009 | 12:42 PM
HOW_i_EGGROLL's Avatar
Originally Posted by JOEDIRT
so Ive had the g for a month now and decided tonight was a good night to take it to some empty business lots and get the feel for some maneuvers (donuts, small drifts, etc.) . I had my VDC off and everything was working fine, the car is awesome, its heavier weight even contributes to the feel in my op. All was well until after a spinout in a failed drift the slip light came on and apparently some type of traction control kicked in and ended my fun. I thought the slip wasnt supposed to come on if VDC is off, anybody know wuts up?
those lights should go away after driving normal a little bit and then shutting your car off and turning it back on.
Old Oct 12, 2009 | 12:19 PM
Yen817's Avatar
also wuts the best way to get rid of those tiny little scratches from rock kickups on the front bumper nd hood (ob coupe).
Yea, even though you turned off VDC it will still somewhat be on but delayed. I think Nissan did this for safety reasons. What you can do is keep on doing donuts even after the safety point until and warning lights start coming up on your dash which means the ECU completely turned off the VDC. Then you don't have to go the hassle of disconnecting sensors. When you're done just restart your car and it SHOULD be fine.
Old Oct 12, 2009 | 12:45 PM
smokincoupe's Avatar
is it the gray connector with 2 wires coming from it or the other light gray connector with alot of wires coming from it
Old Oct 12, 2009 | 01:44 PM
CLEANBS's Avatar
are their any issues with the steering rack breaking or power steering pump failing with heavy drifting on the G Coupes?
Mry
Mar 3, 2023 01:03 AM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
