Question about lowering cars and gas mileage
Old Oct 12, 2009 | 11:58 PM
klee's Avatar
Lightbulb Question about lowering cars and gas mileage
Hi guys I'm thinking about lowering my car and getting spacers and a new set of 19 rays with tires. I was wondering if that would affect my gas mileage. My car is unmodded and full stock. Thanks
Old Oct 13, 2009 | 05:10 AM
NVM's Avatar
NVM
negative
Old Oct 13, 2009 | 07:13 AM
dofu's Avatar
20 Year Member
Not sure about mpg, but it felt like I lost a bit of acceleration when I slammed my sedan. Now that I've raised it back up a good amount, it feels like I have much better power response again.
Old Oct 13, 2009 | 10:07 AM
gary c's Avatar
Gas Mileage....no! But....
Lowering your G will have no effect on gas mileage, it will however have an immediate effect on your wallet....$1200+ done correctly. Springs, suspension package and alignment....
Gary
Old Oct 13, 2009 | 12:03 PM
rasetsu's Avatar
Lowering may improve aerodynamics slightly and thus improving MPGs slightly too, but if you are putting on bigger and wider tires, that will hurt the MPG. It's all negligible. Biggest impact will be on your wallet like Gary C said.
Old Oct 13, 2009 | 12:05 PM
tightvpkid's Avatar
so what are the pros or going wider tires? more traction>?
Old Oct 13, 2009 | 04:04 PM
klee's Avatar
so with 19 inch rims and a lowered car, what are the negatives about that?
Old Oct 13, 2009 | 04:28 PM
otd34's Avatar
diminished ride quality (depending on the spring rate you choose)
Old Oct 13, 2009 | 05:42 PM
dofu's Avatar
20 Year Member
Actually, I'd disagree with that. The larger wheels should give you a better ride quality because the larger diameter wheels and tire combo will be able to roll over bumps easier. But if you put lower profile tires on, then you'd get a louder, harsher ride because of the lack of sidewall to help absorb everything. If you stick with 40+ sidewall tires, then you should be fine. The more sidewall, the better the ride quality.... Also, a lower sidewall will give you better response due to less sidewall flex, but a larger, heavier wheel will be worse on acceleration. (just different points to think about)
Old Oct 14, 2009 | 12:37 AM
gary c's Avatar
Dofu....you funny sedan guy! Wider tires than OEMs will make your G handle better. I always disliked using those 225s in the front, but that's Nissan's thing not mine. I like the stability of having slightly larger quality tires on my rides....245F and 275R in 35 series. (my thing)
Gary
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
Kal Hamm
Jul 24, 2015 08:55 AM
