M45 shift gear knob?
Old Oct 24, 2009 | 12:00 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
It took my shifter a while to loosen up, but the button did require more pressure to release the shift lock mechanism. The reason is that I was still using the white stock plastic piece (from 03), and it was about 2 mm taller than I would like. However, I couldn't grind it down any further without losing structural strength.
Fitting a shift boot will depend on the year of your car. I had to do more work with the 03. This was the final product:
Old Oct 26, 2009 | 07:09 PM
caskyline's Avatar
Former Vendor
I have no problems shifting it in and out of gear. The button does have to be pushed a little bit more than the original oem one.
Old Oct 28, 2009 | 07:17 PM
EndlessWaltz112's Avatar
Sorta off topic, has anyone used a spring adapter to use any shifter ****? Would any adapter work on it? Cause I saw this and this made me wonder how was this one done. Is this anyone's auto shifter on here?
Old Dec 22, 2009 | 11:40 AM
WTFisJUICE?'s Avatar
Sorry to revitalize a decently old thread, but EK , did you cut that shift plate? What shift boot and **** did you use? A write up would be sick. LOL
Ive never seen a shift mod for the 03-04 coupes this clean. -_-
I want.....
Old Dec 22, 2009 | 07:24 PM
OneOfaKindTrini's Avatar
The material on that M45 Shift **** is sweet. I'd love to see that on a 6mt.
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
