Thumping sound coming from rear
Old Nov 7, 2009 | 07:27 PM
SteveZ's Avatar
Wheel damage if it's not the tire. My first guess would have been tire was coming apart internally a little. Things that thump and increase with speed mean rolling parts, unless you have an axle issue on that side, I still would look to the tires/wheels. It's not unheard of to get a lemon tire out of the box, either.
But I say wheel, it's been dinged somehow.
Old Nov 7, 2009 | 07:32 PM
SteveZ's Avatar
Originally Posted by ali7up
yea as i suspected it was the rear tire that was making the noise, and also found out that the clutch will need replacing soon, AC, PS, AT belts need replacing, and cabin filter needs replacing. Also my 30K service is overdue.
DIY on the cabin filter, that is a notorius rip-off repair for the labor, and they jack up the filter price, too. The only thing more shameless I have seen from the dealership was the price to replace the PCV valve - a $12 part - was something like 0.50 hrs labor and $30 for the part. Order it online, just pay close attention to the directions and don't force anything removing the old one.
The clutch, all I can say is do your research for alternatives, and be sitting down when you hear the dealer estimate.
The belt change is awkward for a DIY from up top, and from underneath you have 30 bolts or so just for the cover, and w/o a lift it's not fun. I'd punt that one to the shop.
Old Nov 10, 2009 | 02:23 PM
ali7up's Avatar
Im gonna replace filter and have my buddy change the belts. I checked the clutch and they told be anywhere from $2500 and up. So im going aftermarket and have a shop install them.
About the noise i just talk to the service guy and he said the back caliper was sticking and causing the noise. Should get more details once i pick it up.
Old Nov 10, 2009 | 06:36 PM
TheG35Dude's Avatar
Belt change is easy if you have a set of ramps with extensions, while your under there do the oil and filter change and save some more money.
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
TWASkyliner
Feb 8, 2020 08:00 PM
mjfenix
Aug 17, 2017 05:49 AM
