Help: my car is leaking oil
Old May 2, 2019 | 06:23 PM
DVocalz Mda's Avatar
just brought a this car and i show a couple of drops of oil on the ground
Red face Mr. Surgon
hey I recent just brought a 2003 infiniti g35 and I show a couple drop of oil on the ground but I don't know if its a oil leak
Old May 2, 2019 | 06:29 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get it up on jackstands and clean everything thoroughly, then use an inspection mirror and a good flashlight to find the leak if it drips anymore.
Old May 6, 2019 | 07:01 PM
herrschaft's Avatar
Its probably leaking where the oil filter attaches to. But yes, find the leak first.
Old May 6, 2019 | 07:39 PM
telcoman's Avatar
Veteran: Army
After you check what others above have posted, there are more than a dozen bolts that bolt the oil pan to the engine block. They may be 10 mm bolts but I'm not positive of the size. There is a gasket between the oil pan and the engine block. Some of those bolts may have loosened over time due to engine vibration. Check all of them using a 3/8 in drive socket wrench with the correct size socket to make sure none of them are loose. Be careful and don't over tighten them or they'll break. It is possible some of your oil leak is coming from there?
Telcoman
Old May 6, 2019 | 08:44 PM
G2B35AGN's Avatar
Check the FSM for the oil pan torque values. Don't just go free-handing it.
Old May 6, 2019 | 08:49 PM
cleric670's Avatar
BANNED!!!
Lower oil pan is 78 INCH lbs.
ghost_g35
Aug 7, 2015 10:31 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
