How to avoid too much tire spinning at launch?
Old Nov 16, 2009 | 12:55 AM
856-ZIC's Avatar
Hi guys! Here is the situation. I just installed the sprint booster yesterday, and it works just as great as they advertise. The problem is that now I have too much spinning at the tires as I floor it at launch (of course with traction control off). The tires keep spinning non-stop until I have to loose the gas pedal a little. It's so easy to burn out my tires now. I can even spin it while I'm at 15mph. Is there anyway to limit this? Thanks.
Old Nov 16, 2009 | 12:59 AM
CLEANBS's Avatar
lots of practice, or leave VDC on
Old Nov 16, 2009 | 01:07 AM
856-ZIC's Avatar
practice doesn't help. I've been trying all day, and it's just way too much spinning. I still have 50-60% of tread left on my tires. Thanks for the advices tho.
Old Nov 16, 2009 | 01:12 AM
4DGS's Avatar
What toyos are you running? How are you launching?
Old Nov 16, 2009 | 01:21 AM
856-ZIC's Avatar
Proxes T1-S. 255 front, 275 rear. For the launching part, I just simply floor the gas pedal without revving it to 3000-3500 rpm or anything...
speedracerg35's Avatar
why are you flooring the gas pedal?
Old Nov 16, 2009 | 01:26 AM
wise-1's Avatar
Umm, what do you expect from flooring the gas pedal from a stop? I suggest trying to ease off the gas pedal.
Question to you however, how are you revving your motor to 3000-3500 on an auto without neutral drops or pre-loading the converter to a ridiculous load.
Old Nov 16, 2009 | 01:27 AM
4DGS's Avatar
Something is wrong there.
Launch from higher RPMs, the sprint booster might be tricking the ECU more than it should.
Old Nov 16, 2009 | 01:28 AM
856-ZIC's Avatar
well, obviously I try to test my 0-60 time since I just got the sprint booster.
4DGS's Avatar
Brake in then let go from RPM. It's not that much strain on the converter, this is the way ALL automatics are launched.
Old Nov 16, 2009 | 01:38 AM
856-ZIC's Avatar
I think it would even hurt your 0-60 time if you do this. Trust me. I did that before. It's slightly better when I rev it to 3k in neutral then kick in D.
Old Nov 16, 2009 | 01:42 AM
umair's Avatar
dont wanna spin.... could be the tires? might i suggest the vredestein ultrac sessanta
i have them on mine and well i havent made an effort to the same degree as you have but i will in the morning and let you know how good or bad they spin
Old Nov 16, 2009 | 01:43 AM
856-ZIC's Avatar
Thanks
Old Nov 16, 2009 | 01:48 AM
umair's Avatar
IN DRIVE????
not using the tiptronic...?
btw... revving then dropping in gear... cant be good for trany
Old Nov 16, 2009 | 01:51 AM
856-ZIC's Avatar
IN DRIVE????
True, That's why I've only done it twice^^. Not using Tiptronic because D is right next to N, so it's faster
