pro-charger OR Twin Turbo charger
Old Aug 22, 2004 | 08:04 AM
G35WANTED's Avatar
hi guys
i wanna ask which charger is better for the G.
- the HP
- the 0-60
- the performance
- the cost
thanks alot
Old Aug 22, 2004 | 09:54 AM
EX250's Avatar
Re: pro-charger OR Twin Turbo charger
As for the cost, superchargers will always be less expensive than a TT setup. Less to change, less to tune. There are alot less variables to deal with with a S/C install, as well as tuning so cost wise, the S/C wins.
Comparing from what I've seen, 400+ Hp seems to be normal for tuned, s/c G35's on this board, and from what companies the likes of Greddy, PE, TS, and JWT have said, that is their target hp as well.
However, the max PSI I've seen out of a S/C G35 is ~10 psi, while you can tune a TT all the way up to whatever the turbos can handle, and I know JWT offeres a 500+ hp big TT setup already.
2003.5 G Coupe premium. 6MT Black/black
JWT/Z tube, UR pulley set (chrome), Crawford v5 plenum (black), Crawford Cats.
Proud to have more hp than a stock 05 =)
Old Aug 23, 2004 | 02:40 AM
G35WANTED's Avatar
thanks 4 ur reply
w'll the TT is better than the s/c but it's cost more
but can i turn the s/c psi over 10 PSI
and it both of the charger need rebuild engine
thanks alot
Old Aug 23, 2004 | 03:58 AM
kwakman's Avatar
If you want the max performance out of each setup, i believe the TT is the best way to go. There's less parasitic loss and the torque numbers seem to be a lot higher on TT setups compared to S/C's.
'03 G35c DG/G 6mt, full options
Old Aug 23, 2004 | 06:00 AM
G35WANTED's Avatar
thanks guys for the info
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
