car turns off while driving!!!! help please!!
Old Dec 1, 2009 | 10:34 PM
sergg35's Avatar
wasup fellas, i have a 04 auto coupe. driving the g to skool today and going there and back it died on me 4 times!!!!! not once 4!!! ... wut happens is the car jus dies and all my lights come on ( vdc, check engine, slip, ect)... has anyone had this problem???
Old Dec 1, 2009 | 11:52 PM
VictoriousG's Avatar
Might just be your car battery did you check that yet?
Old Dec 2, 2009 | 12:46 AM
partyman66's Avatar
Please provide more details. What was the weather like outside when it was stalling(very rainy, deep puddles, real hot, etc)?..... have you had any other problems lately?... is your fuel economy and/or power way down of late?.... does the car sound weird?... what were you doing when it died(stopped, accelerating, decellerating)... did it overheat at all or make any weird smells or smoke?
Was your car sitting for a long time? What kind and what octane gas are you using? Have you ever cleaned your MAF sensor? Do you have any mods on your car?
Old Dec 2, 2009 | 07:44 AM
Mike Mike17's Avatar
i had this when i first got my car it would do it at stop lights sometimes. Its almost as if it stalled out like a manual. I got an oil change the next day cause i was due and after that it stopped.
Old Dec 2, 2009 | 08:32 AM
OBG3506's Avatar
Check for loose battery cables and Hope its not an electrical problem
Old Dec 2, 2009 | 10:38 AM
OPTiK's Avatar
Get your alternator tested for free at autozone.
edit: Your battery is only really used to keep things on when your car is off, and for starting your car. Your
alternator is what keeps your car on when your driving, if your alternator is giving out then your battery may
try to compensate, but if its extreme then your car will turn off.
Old Dec 2, 2009 | 12:28 PM
OBG3506's Avatar
Tell that to my Tahoe when the cable is loose that SOB would shut off mid curve!! Get out tighten the cable and she was as good as new, the alternator tested good!! Crazy!
Old Dec 2, 2009 | 12:35 PM
partyman66's Avatar
That's not the case with modern cars.... You need an a battery for things to work right while the car is running... not like the old days of carbureted vehicles.
Old Dec 2, 2009 | 01:08 PM
goodlife's Avatar
Add gas
Old Dec 2, 2009 | 01:10 PM
dave's Avatar
Do you have a cold air intake?
Does it die when you are giving it gas? Or does it only die when you are not pressing down on the gas pedal?
Old Dec 2, 2009 | 01:17 PM
LightsOut's Avatar
SIETESG
guessing... if you have a cold air intake like AEM. I've read that they cause engine shut off, due to the air flow. something like that
Old Dec 2, 2009 | 01:20 PM
LightsOut's Avatar
SIETESG
believe your issue was a short
other guy is right
Old Dec 2, 2009 | 01:52 PM
OPTiK's Avatar
Really? My buddy's car (civic) remote start went nuts one time and wouldn't turn off so he disconnected the battery to try to turn the car off, and it kept running!
Old Dec 2, 2009 | 03:49 PM
partyman66's Avatar
Hit the brake... it'll probably shut off unless the engine is revving like crazy to create more current since it thinks the battery needs charging.
Old Dec 2, 2009 | 08:44 PM
sergg35's Avatar
hey fellas ok so i got the g scanned today... a code p2135 came up ... it says its the throttle pedal position sensor.... i dnt kno how much this part is and i dnt wana get ripped off!! i dnt have a cold air intake and the weatehr was bout 40 degrees and i wuz using it all day so it the engine wuz already warmed up
