Re-sealing tail lights
Old Dec 15, 2009 | 02:32 PM
bitsq's Avatar
Hey guys,
I got my hands on a used set of tail lights for my car, so i decided to cut them open and paint the inside black. They turned out really good, now i'm trying to decide on how to reseal them.
any ideas what i should use? silicone?
anyone else do this mod?
Old Dec 15, 2009 | 02:49 PM
GR6RR's Avatar
silicone is my best friend... I use this stuff on all different types of things...
Old Dec 15, 2009 | 02:52 PM
elayman's Avatar
I recall reading about using glue to first seal it together and then silicone? I don't think silicone will be strong enough if your taillight gets hit by something but not sure
Old Dec 16, 2009 | 02:20 AM
drifts500's Avatar
I heard that silicone makes fog inside of the light. Rubber is the method from what I heard. But, dont trust me.
Old Dec 16, 2009 | 12:08 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I use a combination of JB Weld and Goop (you can buy both at home depot). The Goop comes in a blue tube.
Old Dec 16, 2009 | 12:12 PM
IrockAG35's Avatar
Ohio G Club moderator
ive done this in the past and had a bit of trouble resealing them..i found that a black DAP watersealant(used on house roofs) works best and looks better too since the inside housing is now also black..keep us posted and post some pics too
Old Dec 16, 2009 | 10:42 PM
SxSkyLinexS's Avatar
theres a lot of ways to do this the best way you gotta debate. ive seen my buddy use rubber and it came out good.
post pics when ur done though
Old Dec 16, 2009 | 11:47 PM
EnerOnE's Avatar
go to home depot and get silicone
Old Feb 6, 2010 | 12:03 PM
bitsq's Avatar
i used silicone on one and it looked like **** and didn't seal very well.. gonna try the jb weld and goop
Old Feb 6, 2010 | 12:05 PM
WILLIE BEANS's Avatar
+1 on jb weld .. that stuff works on everything .. lol ..
Old Feb 6, 2010 | 12:27 PM
erklep's Avatar
epoxy?
Old Feb 6, 2010 | 12:34 PM
xXHotelCrazyXx's Avatar
Got pics? im curious to see what they look like. How did you split them? Did yo uput them in the oven for a bit like headlights?
Old Feb 6, 2010 | 12:38 PM
erklep's Avatar
pretty sure tail lights have to be cut open with a dremel. i did a set of altima tails a few years ago and they were glued together not sealed like the headlights. +1 for pics
Old Feb 6, 2010 | 07:13 PM
bitsq's Avatar
that blue goop from home depot was junk...
I ended up using just an off the shelf clear silicone with a cocking gun and a smoothing tool (cant remember what it was called)
it did an awesome job
i'll take pictures on monday
Old Feb 6, 2010 | 07:15 PM
bitsq's Avatar
yep, i had to cut them open with a dremel, it took a while!
