burning clutch?
Old Aug 26, 2004 | 03:26 AM
zeero's Avatar
burning clutch?
Hi guys, I just recently noticed that after driving my G, I can faintly smell something that resembles burnt rubber. I checked the tires and engine and it doesn't seem like the smells coming from there. I dont really drive my car too hard, shift between 3-4k and my car has only 4000 miles on it. Do you think that my clutch might have some problems?
Old Aug 26, 2004 | 03:34 AM
zeero's Avatar
Re: burning clutch?
Nevermind, found the problem, i found a shopping bag melted on to the bottom of my car. But I also found alot of fluid dripping below the car....Seems like a/c fluid, what do I do about this?
Old Aug 26, 2004 | 04:11 AM
CKwik's Avatar
Re: burning clutch?
A/C fluid is actually refrigerant. It is a gas at low pressure and a liquid under high pressure. When released into the atmoshpere it will evaporate and you will never see it. What you are seeing is probably the condensation that forms at the drier. The water that condenses at the drier is allowed to drain underneath the car.
Old Aug 26, 2004 | 06:01 AM
zeero's Avatar
Re: burning clutch?
hmm....but theres a lot of it below the car every time after i drive. Is this normal?
Old Aug 26, 2004 | 07:12 AM
gte192t's Avatar
Re: burning clutch?
Yes, seeing a river-like stream of water under your car after driving with the A/C on is normal. I say 'river-like' because it usually looks like a river, not because it is large as a river. I guess it could look like a puddle if you were parked on an exactly level surface.
-Chris
prinny
Nov 22, 2015 11:07 PM
Vqalexisz
Oct 14, 2015 12:48 AM
AL8782
Oct 3, 2015 10:26 AM
Learned Hand
Oct 1, 2015 09:02 AM
