mix match tires
Old Dec 22, 2009 | 07:00 PM
EF21's Avatar
mix match tires
So i went home to Los Angeles to visit my family. My rear tires were bald so i had to replace fast. So got some OEM Potenza for cheap but my fronts are TR-1. So can i keep the TR-1 till i can replace my fronts with OEM or not drive aggressive at all.
Old Dec 22, 2009 | 07:12 PM
NjMatteSedan's Avatar
i used to have 4 different brands of tires on each of my 20" wheels lol didn't have any issues
Old Dec 22, 2009 | 08:52 PM
2K6G35c's Avatar
I would not recommend mixing and matching any more than two wheel brands BUTT, you should be fine with your mix. I'm currently running Toyo's up front and Falken's in the rear. So far, after 8K, not a single problem.
Old Dec 22, 2009 | 09:00 PM
Dubi2087's Avatar
As long as you have the same speed rating and same tires on the same axles than you have nothing to worry about. The most important thing is the Speed Rating. If the speed ratings Match than you have nothing to worry about. As long as they are close you have nothing to worry about.
Old Dec 22, 2009 | 11:47 PM
bocatrip's Avatar
The Load rating is also important. The replacement tires should equal or exceed the recommended load rating.
Old Dec 23, 2009 | 03:54 AM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
ya i was also wondering about this. there was another user complaining about VDC going on from time to time when cornering. he possibly got significantly different tires tho.
right now i have summer and winter tires. for my summers they are all pilots, and i'm probably going to replace the rear tires with something cheaper because i can't afford to keep going through tires that cost like 300 bucks a pop and have a low tread wear rating. i can get similar quality tires for under or about 200 that have a 20-30% higher tread rating.
to clarify, i don't have both summers and winters on, just the winters right now. i was just saying i have 2 different sets
Old Dec 23, 2009 | 04:19 AM
JOKER's Avatar
CLUB MODERATOR
Check out Vredestein Ultrac Sessanta. You can get them a little under $200 in most cases/sizes and they outperform most $300 tires.
Old Dec 23, 2009 | 05:06 AM
j 4 lD's Avatar
you mean Toyo T1R's?
Old Dec 23, 2009 | 10:19 AM
gary c's Avatar
Tire Rack recommends not having 2 different tires on your car, but they sell tires for a living....LOL I don't see a problem cause I've done it in the past with B-stones & Michelins....
Gary
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Jussumman
Dec 22, 2015 10:23 AM
Phenomenon9
Aug 9, 2015 01:34 AM
joedaddy1
Jul 28, 2015 02:58 PM
