235/17/50 Wide Ovals on the Front of 04 Coupe
Old Dec 28, 2009 | 05:52 PM
Rufito's Avatar
I have 235/50/17 Firestone Wide Ovals on the back of my 04 coupe. There is no 215/55/17 or 225/50/17 in the Wide Oval series. I read here that some are running the 235/50/17 Wide Ovals on the front. Are there any speedometer issues? Also, would the Firestone Firehawk GT 225/50/17 be a good match to the Wide Ovals in the back?
Old Dec 28, 2009 | 06:29 PM
toyotabike's Avatar
I think speedometer readings are based on the diameter of the wheel and not the width.
Old Dec 28, 2009 | 09:39 PM
twarsop's Avatar
toyotabike is correct. When you start getting larger wheels the speedometer will become off depending on what size you go down/up to, not the width of the tire. A google search should give you a graph somewhere.
Old Dec 29, 2009 | 10:39 AM
Rufito's Avatar
OK, good to hear there is no speedometer issue.
Anyone with long term experience running the 235/50/17 on the front?
Old Dec 29, 2009 | 10:42 AM
twarsop's Avatar
By the way, here is a neat little calculator that may help you.
http://www.kouki.co.uk/utilities/vis...ize-calculator
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
laksjd84
Jul 24, 2015 05:12 PM
EasySausage
Jul 14, 2015 11:17 PM
