Oil change
Old Dec 31, 2009 | 03:52 PM
infinitisport's Avatar
Wusseeee
I don't think it's worth the time plus I don't have the drain container and ramps. If it were a BMW $150 oil chane yea I'd do I myself [/QUOTE]
What???
You don't need a ramp???
You don't even need a drain container???
Worth who's time???
It only takes 1/2hr to change your oil and you can use your spare tire tools and a couple to bricks for added safety while you're at it - use your mama's or 5 gallon cooking oil plastic container if you can't afford a drainer - the time it took you to come up with excuses not to do it you could have been done by now or the time you sit a the dealer waiting for your oil change you could've change your oil 5-6 times already.... Wuss?????
Old Dec 31, 2009 | 09:28 PM
gary c's Avatar
Originally Posted by bigc
i'm adding an oil cooler on my next change so i figure this will be the best time to do a complete fluid swap
You're kidding, right Chris? If you haven't switched "Why did you wait this long?"
Gary
Old Dec 31, 2009 | 09:57 PM
SxSkyLinexS's Avatar
ill change ur oil for you
drive 2 my house pay me 30
Old Dec 31, 2009 | 10:05 PM
thescreensavers's Avatar
Mr.202?
eh, dropping my car an inch wont let me roll on my ramps any more dang lol. Time to make a wood fab lol.
Old Dec 31, 2009 | 10:21 PM
^ dig a hole in the middle of ur garage u can chang ur oil that way
Old Jan 1, 2010 | 10:27 AM
gary c's Avatar
HAHA that's funny! Make yourself some "Roll Ups" out of 2X4s, I never leave home without mine.
Gary
Old Jan 1, 2010 | 11:38 PM
cmesurf's Avatar
where are you in OC?
Old Jan 1, 2010 | 11:46 PM
bigc's Avatar
Wings Nation
Gary
don't hurt me Gary!
conventional has been fine thus far, but with the extra heat from the SC i think it makes more sense to go synthetic.
Old Jan 1, 2010 | 11:55 PM
cmesurf's Avatar
no...., I was going to help.... but you are doing ok for now... I use Mobile 1 5-39 and I change oil/filter every 6 months or 5k miles... it cost me $40 (oil $35+ filter+ drainplug gasket/washer and city picksup oil & filter no charge,,,in their recycling cans) and I get to keep my car clean and running smooth.. I have over 100k MILES.....
Old Jan 2, 2010 | 01:04 AM
Dablakbradpitt's Avatar
Originally Posted by grovefromnh
Remember to drain the oil cooler also or there will be 1-2 qts. of dirty oil in it. fill cooler seperatly so nothing run dry when you first start it after an oil change. also, good time to plumb in a remote filter to replace the small stock one that is a pain to remove/replace. much bigger oil filer fram PH7 + more oil for your engine.
where is the oil cooler located
Old Jan 2, 2010 | 01:21 AM
cmesurf's Avatar
Right behind the oil filter.
Old Jan 2, 2010 | 01:38 AM
bigc's Avatar
Wings Nation
the stock oil cooler has coolant circulating around it and is there primarily to help your oil get up to operating temps quicker. that's the one located between the oil filter and the oil pan. i think 'grovefromnh' is referring to an aftermarket, remote oil cooler which most people mount somewhere behind the front bumper. i'm not sure how 1-2 quarts of oil could wind up in the stock cooler
Old Jan 2, 2010 | 01:47 AM
cmesurf's Avatar
The after market oil cooler is mounted behind the radiator- See
http://www.conceptzperformance.com/C...67.195.111.244
Old Jan 2, 2010 | 01:52 AM
bigc's Avatar
Wings Nation
the end user can mount an aftermarket oil cooler wherever they like, however, behind the radiator would not be the best place. its not even really possible since the OEM fans are in the way.
for max performance, you mount it in front of the radiator or somewhere with direct air flow (ie behind one of the holes in the front bumper).
Old Jan 2, 2010 | 01:54 AM
  #30
cmesurf's Avatar
yes... that's correct.
