On Start up..
Old Dec 29, 2009 | 07:55 PM
DUS10's Avatar
On Start up..
2004 5AT COUPE
After my car sits for a while (anything longer than about 5 hours). Icrank the car and the rpms go to about 1200, then go all the way down to about 100 and almost shuts off then catches itself and goes to a normal idle.
It only does this if it has been sitting for a while.
Any advice will help. thanks
Old Dec 29, 2009 | 09:56 PM
monteitis's Avatar
Hi DUS10,
I had the exact same problem soon after I purchased my used G. It would only happen on cold starts... after the initial "surge" in RPM after turning the key, the rpm's would drop to a car-shaking, near-stalling level. I took it to the dealer and they cleaned the throttle body and fuel injectors. Never happened again...
Old Dec 29, 2009 | 10:10 PM
DUS10's Avatar
Thanks!
Ill try this out for sure
Old Dec 29, 2009 | 10:19 PM
monteitis's Avatar
Np, I'm almost positive it is the same issue I had!
Old Dec 29, 2009 | 10:43 PM
g37musings's Avatar
! second throttle body.............
magnetism80
Feb 1, 2019 10:00 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Jnm07
Sep 5, 2015 01:16 AM
kevintandmd
Sep 3, 2015 06:41 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
